RennTech.org Forums: cayenne sat nav problem - RennTech.org Forums
Page 1 of 1
  • You cannot start a new topic
  • You cannot reply to this topic
cayenne sat nav problem sat nav shows i'm 30 miles away?????
#1 User is offline   jmccrabbe
  • Member
  • Icon
  • View blog
  • Group: Members
Post icon  Posted May 19, 2008 - 09:04 PM
Hi all,
May possibly be a very stupid question but my location cursor on my sat nav screen
shows i'm approx 30 miles north of my actual location? I've actually driven 40 -50
miles beyond this location (northerly) and the cursor then appears to be to the south of me???
I.E. it appears to be "stuck" within a 5 miles radius????
Is there any way to reset the cursor to my actual location or "zero" it?
my Nav CD is (as far as i'm aware) the most recent one?
Any help or suggestions would be appreciated.
James.
#2 User is offline   RFM
  • Moderator
  • Icon
  • Group: Moderators
Posted May 20, 2008 - 10:18 AM
Check the quantity of satellites the PCM recives in the open air, if you reed less of 4 you got a GPS antenna failure, not uncommon problem on Cayenne.
Life starts @ 7.000 RPM
#3 User is offline   jmccrabbe
  • Member
  • Icon
  • View blog
  • Group: Members
Posted May 20, 2008 - 01:11 PM
that would certainly seem to point to the problem as there are no satellites found at all, any ideas as to where the gps antenna is located or is it integrated (i.e. very expensive no doubt!!!) into the sat nav unit?
Thanks for the info :)
#4 User is offline   mudman2
  • Contributing Member
  • Icon
  • Group: Contributing Members
Posted May 20, 2008 - 03:47 PM
They are inside the rear spoiler, most likely its a connection at the headunit, I would pull it and check it out first.
#5 User is offline   jmccrabbe
  • Member
  • Icon
  • View blog
  • Group: Members
Posted May 20, 2008 - 04:44 PM
Thanks for the info, i'm out of the country at the moment but i'll try that as soon as i get home:)
#6 User is offline   cayennenegro
  • Icon
Posted May 21, 2008 - 12:38 PM
How do you check the quantity of satellites the PCM receives?
#7 User is offline   jmccrabbe
  • Member
  • Icon
  • View blog
  • Group: Members
Post icon  Posted May 21, 2008 - 01:17 PM
Not at home at the moment so can't tell you exactly how to get to the screen but on one
of the main navigation screens there is a small banner running across the bottom that tells you how many satellites
your system is recieving a signal (can't be hard to find I think, as i'm a complete novice and I stumbled across it! :))
Someone with access to the system can maybe talk you through finding it.
#8 User is offline   mudman2
  • Icon
Posted May 21, 2008 - 02:55 PM
its on one of the Sat Info menus along with speed and altitude
#9 User is offline   R15H
  • Member
  • Icon
  • Group: Members
Posted May 31, 2009 - 04:29 AM
Hi!
I know its been a while since this post regarding the locked GPS antenna i.e the pcm display stopped showing the actual position on the display with 0 satellites, I have come across the same thing in my 2005 Cayenne and am at a loss.
I was wondering what the outcome of your situation was, were you able to locate the antenna (ive searched everywhere, including rear spoiler and cannot find it)
Or did you have to have it replaced, if so was it expensive (silly question lol)
Thanks very much in advance,
Regards,
R15H
#10 User is offline   RFM
  • Moderator
  • Icon
  • Group: Moderators
Posted June 01, 2009 - 01:00 AM
The antenna is in the rear top spoiler, right side, black square block. It's not that expensive at all (Porsche rules)
#11 User is offline   R15H
  • Member
  • Icon
  • Group: Members
Posted June 01, 2009 - 01:12 PM
Thanks for that buddy,
In order to get to it, hav i gotta take off the spoiler? (im guessing so) as thats really what i cant figure out, is it the case that i need to remove bolts from the inside and get it off?
Basically Porsche UK will be charging £150 minimum to look at it, im certain thats where the problem lies as i've pulled out the head unit and the connection to the gps antenna looks solid, ive looked under my drivers seat and made sure all cables there are in place, the only thing left to do is get to the antenna itself and check connection im guessing, dude and if it is the case that i need to replace the antenna, is it a quick unplug, plug in new one and there we go or is it a case of having to reqire the whole thing from the antenna to the next port of call..
You help is much appreciated RFM, i love my car, with a broken GPS just feels kinda empty lol
#12 User is offline   RFM
  • Moderator
  • Icon
  • Group: Moderators
Posted June 02, 2009 - 07:28 AM
The spoiler cover comes off if you remove the screws, which are located above the glass part of the hatch , on the inside behind round black plastic covers (you have to open the glass part). Lift the spoiler cover on the rear side a little and pull off rearwards. The antenna is screwed on and simple to replace.
#13 User is offline   R15H
  • Member
  • Icon
  • Group: Members
Posted June 02, 2009 - 09:19 AM
I can't thank you enough, I'll try this tom and see how far I get.
I bow to your knowledge.
Page 1 of 1
1 User(s) are reading this topic
0 members, 1 guests, 0 anonymous users
Donate to RennTech.org   Donate to RennTech.org
