Factory Trailer Hitch Wiring Install
#1
Posted May 21, 2009 - 05:18 AM
I have a 2005 V6 Cayenne. I am installing a trailer hitch as the truck did not have one when I bought it.
My plan is to install the Curt aftermarket hitch and the Porsche factory wiring and controls.
I have purchased the Porsche factory parts as follows:
955-618-040-10 Control Unit
955-612-506-00 Wiring Harness
PNA-955-118-93 Trailer Hitch Connector (this is the 7 pin Pollak connector)
PNA 955-127-08 7-4 way Adapter
I am going to get the Curt hitch installed saturday at a hitch shop but plan to install the wiring/control unit.
I have done a search and reviewed the TSB (I could only find the TSB on the electric trailer hitch), but I'm wondering if anyone has some advice on the install process for the wiring and control unit.
Any help would be very much appreciated.
Brent
#2
Posted May 25, 2009 - 05:46 PM
Hello Brent,
The control unit is a small plastic box and if I remember there is 2 or 3 plugs to attach on the module. If you look on the trunk on the passenger side in the compartment over the wheel you will find all the connectors pre-wired. All of them are wrapped with grey foam. At first view the curt kit may look to cost you less, but if you buy all parts piece by piece, it's cheaper to buy the original kit. I installed by myself in about an hour max and I'm not a top mechanical. You need only to remove the crossmember put the hitch and foampart and clip all the plugs. All of them have different size and shape and it's impossible to make a mistake. The only bad thing is the new cayenne model come with smaller size bolt to hold the hitch. I needed to buy specific bolt to hold it, this is steel structure bolt category. The price to buy 8 bolt at porsche dealer was the cost to buy a full box of 48 at a specialized bolt store. So if you need some I'll give you 8 at no charge, you just pay the shipping cost. (I have 40 left if this can help you) M14 100mm I had ordered a curt kit and resell it on ebay.... When you will see the difference side by side it's like day and night.
I strongly suggest to buy the P4 brake controller, it's like having nothing in tow and dont need any adjustement.
I'm pulling a 5,000 lbs trailer regulary with my v6 and the cayenne is a very good towing vehicule.
The TSB is attached, if you have any question, dont hesitate to ask,
GUY
Attached image(s)
Attached File(s)
Hitch_1D6.pdf (230.8K)
#3
Posted May 26, 2009 - 10:08 AM
cayenne69, on May 25 2009, 05:46 PM, said:
Hello Brent,
GUY
#4
Posted May 28, 2009 - 07:05 PM
May be at max 1.5 hour to do everything. And if I change for another cayenne, I will redo again in one hour sharp. Keep your crossmember just in case. I have a 04 cayenne V6 see larger picture with our trailer, 11,000 pounds for both vehicule at the scale.
If you need any supprt or document, let me know.
GUY
#5
Posted May 29, 2009 - 11:30 PM
does anyone use this?
and the link:
Andersen trailer hitch
This post has been edited by stealthTT: May 29, 2009 - 11:31 PM
#6
Posted May 30, 2009 - 11:46 AM
GUY
#7
Posted May 30, 2009 - 10:25 PM
and the link:
I've been using one to tow my boat.
and...
#8
Posted June 01, 2009 - 04:58 AM
and the link:
and...
very nice, that's what I was looking for. I usually trailer the offroad bike, and some times maybe a boat or a small trailer.
could you please tell me which was the model that you've got? I mean, there are different dimensions and I dont know what to choose.
thanks,
Ilie
#9
Posted June 01, 2009 - 07:24 AM
thanks,
Ilie
Its an 06 CS.
#10
Posted June 02, 2009 - 06:54 PM
#11
Posted June 03, 2009 - 03:41 AM
irsikm22, on Jun 2 2009, 07:54 PM, said:
#13
Posted June 26, 2009 - 10:34 AM
Just curious how the hitch installation went. I am looking to do the same thing and just looking for input on the project.
Do you have any pics of the completed install. What did u use to cut the fisca on the bumper. Also i have rear sensors on my 04 cayenne s, with they have to be reprogrammed ?
Brent
#14
Posted June 26, 2009 - 10:42 AM
Thanks.
cayenne69, on May 25 2009, 06:46 PM, said:
Hello Brent,
GUY
#15
Posted June 26, 2009 - 11:14 AM
Brent
#16
Posted June 30, 2009 - 07:11 AM
Brent
#17
Posted July 06, 2009 - 12:39 PM
Brent
Sign In
Register
Help
MultiQuote
