First of all, the database does not contain district names such as Dorchester. Instead, I have to enter Boston and pick from zip codes if certain streets exist in more than one district, or enter the zip codes directly. However, it seems that the PCM3 does not give a crap about my input, but picks the zip code that it likes.
If you live in Boston area, try searching for 90 Harvard Ave, Allston, MA 02134. You will end up at 90 Harvard Ave, Dorchester, MA 02121, which is about 20 minutes away. You can also look up 500 Washington St, Dorchester (enter "Boston" instead), MA 02124. It will bring you to 500 Washington St, Boston, MA 02111 instead, no matter which zip code you pick from the list.
Is there an upgrade that can solve this?
On the other hand, PCM3 gives too much weight towards big streets and tends to ignore small alleys which are always much faster than the former. Is there any way to adjust it?
This post has been edited by AlienGG: May 25, 2009 - 04:13 PM
Help
View Registry
