Warranty ran out 20 days ago and now CEL
#1
Posted June 05, 2009 - 07:23 PM
#5
Posted June 09, 2009 - 04:58 AM
wvicary, on Jun 8 2009, 07:42 PM, said:
Originally the cel came on but car was running normally. Have never had any type of code or problem w/ car in two years. When I refueled the car and tried to start it wouldn't turn over. I gave it some gas on third attempt and it turned over but idled roughly for a minute. I drove about a mile and stopped at stop light. Car was fine. i had only put $20 in car as it was all i had on me. Two days later I went to fill her up and car had driven fine w/ no incidents. After refuelling it once again did not want to turn over. Gave it some gas and we are running fine again. Ordered durametric and waiting to receive. Warranty just ran out May 13. thats the sucky part. thanks
#7
Posted June 12, 2009 - 05:14 PM
PO455 Evaporative emmission system - Leak detected(large leak) present
PO441 Evaporative emmission system - Incorrect Purge Flow - short to ground or positive
1176 immobiliser key
353 Feedback from blower regulator - front short to ground or positive
907 Load management operat. on vehicle - electrical system/dme module present
1748 Tip switch on steering wheel up present
I cleared all of the codes and took it around the block. I also opened the gas tank and then resealed. Still no check engine light. We will see what happens tommorow. Any tips on these codes. Thanks guys
#9
Posted June 12, 2009 - 06:35 PM
This post has been edited by 97boxsterred: June 12, 2009 - 06:38 PM
#10
Posted June 13, 2009 - 07:04 AM
97boxsterred, on Jun 12 2009, 10:35 PM, said:
Definitely gonna clean the fuel cap. then maybe i'll have to order a new one from Sunset. I don't think it was bad fuel as I always use premium from same place and the last two times it refused to start after refueling and only did the rough idle when I gassed it to get it started. after running for 15seconds each time, it ran fine for the rest of the tank. It definitely seems that it is something to do w/ the fuel system. HOpefully it is just the cap. Anyone know what all of these codes mean???
#12
Posted June 15, 2009 - 05:48 AM
I would clear the codes and see which ones come back.
Then focus on the engine fault code(s).
#13
Posted June 15, 2009 - 01:49 PM
Can they test the battery at Advanced Auto/Autozone or do i have to take it to dealer?
I cleared all of the fault codes and I have driven twice and none have returned althought I have not filled the car up w/ gas yet and that is when I've had my two incidents w/ not starting. Guess we will see as a refuel is needed in the next day or two.
#14
Posted June 15, 2009 - 02:38 PM
#16
Posted June 15, 2009 - 05:26 PM
#17
Posted June 15, 2009 - 05:41 PM
Don't forget to connect vent tube (L vent hole), and re-use the plug (R vent hole)
You must use 10mm triple square bit for driver seat bolt removal, do not use 10mm torx. It will strip the aluminum screw. It's tightened at very high torque due to threadlocker. Go slow.
My Varta appears to have full charge (built-in hygrometer shows green) but no more capacity. 20 minutes of stereo -> wouldn't crank. (but will crank if I don't use accessories).
Autozone has 3 year replacement / 8 year pro-rated warranty so I suggest to just replace it; it's only $134.
#20
Posted June 18, 2009 - 03:42 AM
shastamonk, on Jun 18 2009, 12:41 AM, said:
Regards,
Scott
thanks scott, I'd thought the same thing. Is that a costly fix? wonder how much from Sunset Imports?
Sign In
Register
Help
MultiQuote
