RennTech.org Forums: Check engine light P0011 and P0455 - RennTech.org Forums
Page 1 of 1
  • You cannot start a new topic
  • You cannot reply to this topic
#1 User is offline   benhurmx
  • Member
  • Icon
  • Group: Members
Posted June 21, 2009 - 05:12 PM
Lately i have a CEL coming on. I 've ran the Durametric diagnostics and it came with 2 errors;
1- P0011: Camshaft position Timing over
2- P0455: Evaporative Emission System Leak.
Any idea where to begin with ?
Cayenne S 2004
This post has been edited by benhurmx: June 21, 2009 - 05:13 PM
#2 User is offline   Loren
  • Porsche Nut
  • Icon
  • View blog
  • Group: Admin
Posted June 21, 2009 - 05:45 PM
View Postbenhurmx, on Jun 21 2009, 06:12 PM, said:
Cayenne S 2004
P0011 Adjustment of Inlet Camshaft in relation to Crankshaft, Bank 1 – Signal Implausible
Possible cause of fault
- Dirt in oil circuit
- Sealing strips on inlet camshaft adjuster faulty
- Oil pressure too low
- Mechanical fault in inlet camshaft adjuster
- Solenoid hydraulic valve faulty
P0455 Evaporative Emission System Leak Detected (large leak)
- Tank cap not tightened correctly, faulty or missing
- Mechanical fault in EVAP canister purge valve (does not close fully)
- Leakage diagnosis pump leaking internally (membrane) or externally
- Mechanical fault in EVAP canister shutoff valve (does not close fully when power is supplied)
- EVAP canister shutoff valve connections leaking
- Tank system (including pipes) leaking
Loren
RennTech.org
PCA member since 1978
My Mods in the Registry · My Blog
#3 User is offline   benhurmx
  • Member
  • Icon
  • Group: Members
Posted June 22, 2009 - 07:34 AM
Thanks for the fast reply. I ordered a gas cap from sunsetimports to start with. He said they've already sold 30 pieces this month. I have to change the A/C blower motor too.
Regards
Page 1 of 1
1 User(s) are reading this topic
0 members, 1 guests, 0 anonymous users
Donate to RennTech.org   Donate to RennTech.org
