I've got it installed and working OK, but the wiring for the old and new units doesn't match, and my main problem is getting a switched positive to the unit. Someone's mention CAN-BUS as an explanation but it means little to a simple soul like me. The unit switches on and off fine, but obviously not with the ignition. A side effect seems to be that when I turn the ignition on the heater control unit doesn't come on till I switch the head unit on. However if I turn the radio off the heater control unit stays on ...
I thought it'd be easy enough to find a switched positive somewhere near, but I can't, so I've run a wire over to the fuse box. Can anyone advise me the best place to connect this or if I'm missing some simpler solution?
Help
sign at the bottom right corner of any post.
View Registry
