Loosing coolant
My first drive in mynew pre owned Porsche certified Cayman S with 9155 miles
Woke up at 4:30 to go on my first drive , empty twsities , perfect conditionds, was very impressed with the car, mostly second gear twisties one after the other non stop I was pushing it and having fun.
One hour later I was
returning and was coming up the twisties, mostly thigh turns and after the
other second gear uphill, fast ,when I got the light of check engine
coolant, and the temperature started rising, I stopped let it cool down and
drove it slowly to the gas station (the dial never got to the red part but
was 3/4s.
Waited 1 hr for the car to cool down, and I put in the car a full gallon of
coolant
Drove again in the twisties and 8 miles later again, the light of check
engine coolant came on,I stopped inmediatelly since I brought a spare
gallon of coolant, and this time it took 3/4 of a gallon of coolant, Im at
the top of the hills so from there to my house is just 20 miles but mostly
downhill, I drove slow to my house , never passsing 3,000 rpms, the light
never came on again , and the temperature needle never rised from the center.
Seems to be that only when driving the car hard the coolant is lost.
Could anyone tell what could this mean?
  • 6 months later...
Have seen the bleeder valve housing leak on Boxsters. This only happened after the car was hot and while beiong driven. The coolnt was leaking in the form of a mist and the exhaust was burning it before it ever hit the ground. I had to add well over a gallon of coolant before I found the leak. I think the housing is behind the wall where you fill the coolant/oil. At least thats where it is on the Boxster. There were like 6 small screws around the top that had worked their way loose and allowing coolant to force it's way past. This will also allow the engine to overheat due to lack of cooling system pressure.
