Warning Chassis System on 2008 Cayenne Turbo
Once the weather gets cold outside, my multifunction display shows the fault "Warning Chassis System" almost on a daily basis. The fault always occurs when I am turning left and usually occurs within the first 10 minutes of driving. The fault stays on until I turn the car off, they it clears. The local Porsche dealer did not find any stored faults and the one local independent I stopped by with the fault showing could not find any faults using his code reader.
Does anyone have any suggestions? If I bring it to the dealer with the fault showing will they be able to determine the cause or do some faults that clear as soon as the condition clears.
I was not able to pull a fault with my durametric, but was finally able to get to my local indy mechanical with the fault on. He found PDCC/ORS code 15627 Rear Axle Chamber 2 low pressure.
Any suggestions on what is causing the low pressure?
