2017 Macan 2.0L Base Oil Change
Remove the body panel located under the engine compartment by first removing the two large plastic push pin located near the rear corners of the panel using a screwdriver to carefully pry up the center locking pins. The center pins have to pull out almost ½”, so it’s easiest to use a thin screwdriver to pry up the pins to about ¼” prying slowly from each side, then use a 2 pronged trim removal tool or even a needle nose plier to pry it out the rest of the ½”. Then remove the 15 star drive (Torx)
