pcm, no sound, navigation not available, telephone not available, maps not available, cd changer not available
Got a quote from a car audio specialist today and was a bit surprised that they’re quoting £420 for a fibre optic adaptor to work with a Kenwood unit and existing Bose amp. The other option is a new amp at around £400 but the adaptor won’t be required.
There’s nothing in the Kenwood blurb that says an amp is needed.
Does this sound right?
There doesn't seem to be much point in trying to integrate the Bose amp if you aren't sure it is working.
You can get a cable to connect the speakers directly to a head unit, provided the unit has speaker outputs, of course.  The snag is that Bose speakers are 2 ohm impedance, and most head units (and amps) are designed for 4 ohm speakers.  It would work, but the sound quality might suffer.
