Rough running engine - no codes
Actually based on your latest logs, I'm not sure it's a single cylinder issue anymore (there were misfires on cyl 2 & 3) so I doubt a leak down test will reveal anything. May want to just drive it with the MAF unplugged for 1/2hr or so. The performance will be reduced but at least you can feel if it helps the rough idling.
Your cam deviations look excellent so I doubt IMS and cam padding are the issues. BTW, the AOS on your car (MkII) uses a rubber hose and not a bellow.
Drove with the MAF unplugged all the way home ~45 minutes. No noticeable difference in idle after the drive.
The comment from Porschetech3 on the crankcase vacuum being too low has me wondering about the seals you mentioned or anything else that would cause reduced vacuum in the crankcase. Other than the seals you mentioned, should I check anything else when I have it on the lift for the oil change?
Also, my independent Porsche shop expressed a concern about lifters sticking causing this issue. Any thoughts on that?
