Error Code P1128 - Oxygen Sensor
1998 Boxster 2.5L engine
Error code P1128 – "PCM detected the oxygen sensor 2 for cylinders 1 through 3 was at its lean limit."
Can anyone tell me if “Sensor 2” is before or after the catalytic converter?
Also Error Code P1125  for the same bank - passenger side - "Oxygen Sensor Adaptation, Upper Load Range, Bank 1, Above Limit"
No indication of before or after the Cat. Any advice?
