All Activity
This stream auto-updates
  1. Past hour
  2. Today
  3. Yesterday
  4. Using the Durametric tool I have code B05 Drivers Circuit calling for part 996 618 219 01. Does this indicate I need to change the sensor or should I be looking at something else? The car is an 02 C2.
  5. Thanks Richard, I was hoping you'd read this. I should have updated my profile, I actually now have a 2010 997.2 C2, profile fixed now BTW. I provided the link to this post to them, I don't know whether they followed your instruction to the letter. Since I'm bringing the car to OPC, and there isn't a lot of 911s in Wellington (New Zealand) so this might be the first one they have to do. So I'm hoping to be able to get them to read through a set of instructions rather than doing trial and error. The indy said that using Durametric, the DME didn't show an option for cruise control. Using their 'older' Piwis, it showed cruise control but didn't accept the setting provided.
  6. it worked! omg thank you so much you just made my week lol
  7. You shouldn't make any changes to the Gateway. Only the DME, Instrument Cluster, and Steering Electronics. Your profile says you have a 2003 996. In that case, look into the DME Vehicle Data, and check that the Order Code is entered correctly. For a RHD C4 Cabriolet, it should be 996611. Then do a FULL Control Module search, and code the instrument cluster and DME for "with cruise control".
  8. Well a week at the dealer and still it's not running. They said to take it to the next level is going to be a minimum of $1,200 on top of what they already charged me and there is no guarantee it will run and the estimate will only go up from there unless of course they find something quickly and they can cover it in the $1,200 but like they said no guarantee it will run. So I'm having the car towed back to my place and will start going through all of the wiring Saturday morning. I have this feeling it's something stupid that everyone is over looking or at least I hope so or it will be a nice lawn ornament. They did initially mention steering column but ruled that out, then it was crank sensor (I did put in a new one) then changed their mind. I'll keep posting till either I get it running or scrap it which I would hate to do as it ran so well initially.
  9. Yeah, don't talk to people who are in this business and deal with similar situations daily (shop owners and former Porsche employees) - yeah, ask people who give uneducated opinions on other forums. Actually, my advice is talk to an attorney and ask him if it could affect your defense if you are involved in an accident.
  10. 1999 boxster CDR-220 Becker Type 4462 Ser# Y5045157 thank you very much.
  11. It is not a matter of personal concerns, it is on the advice of legal counsel. What other website do or do not do does not concern me, but we cannot allow either this site, or me personally, to become the "deep pockets" in the legal equations resulting from actions beyond our control.
  12. Interesting. I had for years not bothered with TPMS' in winter given the initial drop in pressure with very low (below -35) temps and disabled it via VCDS (or VAG-COM) on my Touaregs and RS5. I've never read or heard anyone mention this in any Audi or VDub forum nor Uwe Ross at Ross Tech. But back to my question, would PoCom or Durametric or other be able to disable it? I'm also trying to decide what monitoring system is best for my recently ordered 2019 Macan S. siberian
  13. Let's start with the basics: Year and model of the car, and what code are you seeing?
  14. Hi Oscar..... I've recently had the same code for the same reason. And as you say, the pipe/cat for each bank crosses to the opposite side and muffler. In my case, I found a chaffed sensor wire that was grounding to the chassis. I have a Europipe exhaust system and it's larger pipes/cats make it impossible to deal with the O2 sensors without removing the whole system. Given that I was going to have to R&R the bumper cover and exhaust system, I decided to just replace all 4 O2 sensors while I was at it and not worry about it later. The sensors already had 60K mi on them. Good luck.
  15. Touchy subject. The TPMS is a federally mandated safety system; altering it, or turning it off could result in the party that told you how to do it being held liable if you got into an accident afterwards.
  16. Okay guys, I have been getting the CEL with this code for a while... reset, drive a few times, no light... then returns on way home from Autocross... So I order a post-cat O2 sensor and when I go to put it on, I notice that the Cat for bank 1 (Driver side) is on the other side because the exhaust crosses behind the engine... I assumed that since it monitored the exhaust from bank one that it just plugged in on the other side of the engine bay. I thought I was right because I drove it a few times with no light but on my way to Autocross last weekend, it came on again. Before I start undoing stuff, do I have it backwards or does the car look at it as Bank1 if the sensor is plugged in on the Bank 1 side. As anyone who has done this knows, it is a pain in the butt to get these in and out of a 996 GT3 so prior to subjecting myself to the discomfort, I figured I would solicit advice. Thanks!!!
  17. So seems like I need a new kit with all correct number as seems like they incompatible with each other. Hopefully I will get a kit with the numbers I need :). Thank you everyone for your help.
  18. Managed to find a person in one of the main dealers who was very friendly so have all the part numbers now. Anyone know if the 996.618.262.02 and 996.618.262.00 are same or for a different models?
  19. Try board sponsor Sunset Porsche Parts, they have an excellent online section for searching parts.
  20. 996.618.262.00 is for MY 1997 only 996.618.260.06 is for MY 1998 to MY 2000 996.618.262.02 is for MY 2001 on
  21. Seems like DME is probably the one but what about alarm module. There seems to be a choice of two 996.618.262.02 and 996.618.262.00. Are they different or same. Any idea what the last two digits stand for. I've tried to ring few Porsche Main Dealers but they just refuse to give me part numbers or help me in anyway. Is there anywhere I can check it myself maybe online etc?
  22. Thread revival! So I've just gotten my local indy doing this and while they can code the instrument cluster and gateway modules (symbol shows up at ignition at pos. 2), they can't code DME and steering column control unit. Any idea why? I'm booking the car for the dealer to take a look at as the indy indicated that it might be their Durametric and old Piwis (to 996 only) might be the cause.
  23. Right. Totally right. My light came on at weird moments, but always stayed off for long times. On longer road trips I had a partitioned MacBookAir with me just to clear the air bag just in case. Never had it happen though. My car had the gold contacts in the seat belts. If you do go to a dealership, bring your credit card. Good luck.
  1. Load more activity
