- View Classified Ads
- DIY Tutorials
- VIN Decoder
- Special Offers
OBD II P-Codes - Paint Codes
- Registry
- Videos System
- View Reviews
- Send attachments with PMs
- Option Codes Lookup
All Activity
- Today
Vinney joined the community
Manuel De la mora changed their profile photo
Rodney Morris Todd joined the community
bjd joined the community
Joe1965 joined the community
RoyC joined the community
xavier aubard joined the community
PDT01 joined the community
Blackhawkfan01 joined the community
Dupont joined the community
- Last week
Lost Radio Code - post your request here
MaxLeicester replied to pennyporsche's topic in Lost Radio Codes
Thank you, will try that tmrw. -
Try 1043
I recently purchased a 986 as my first Porsche and did not have the radio code supplied. May I please have a code for: Porsche CDR 22 986 type 4467 seri x5021541 Any help would be greatly appreciated. -
JFP in PA started following Changed over valve location and 2008 - 911(997) Carrera S -PDK - No traction
You need to get the car scanned with a proper Porsche diagnostic tool, nothing else will work properly, and yes that calibration code can be the issue.
- 1 reply
- 1
Hi everyone. Really need an expert's help, to understand what's wrong with this car. Last february, on a regular drive the car suddenly lost traction. Stopped the car, waited a few minutes and then was able to drive the car to safe place. Since then, no traction at all. Car starts normal, allow to engage Drive, you press accelerator and nothing, car won't move. Change the fluid and filter for PDK, thinking it would solve the issue but nothing. Asked a friend that has a Launch Diagnose machine, to diagnose the car. A couple of communication issues, due to a dead battery that were solved immediately, but one error remained: - P1872: Data Record for Hydraulics Calibration is invalid Is it possible that the car won't run, beacuse of this calibration config? Meanwhile, got a Piwis 3 and a VCX SE interface, which connect's to the car, but won't read anything... I believe it might be this software "version" that is corrupted, and I'll try to find a better one. Does anyone have an idea on what mught be the issue, and a possible solution?
JFP in PA replied to Wofford Investments's topic in 986 Series Part Number Requests
Welcome to RennTech Replacing the change over valve on a 986 -
Wofford Investments started following Changed over valve location
I changed the heater valve and the top air hose broke. I hear it connects to the change over valve. Can someone show me where the change over valve is located at? Thank you in advance.
Best short shift kit for 996
JFP in PA replied to johnmh's topic in 996 Series (Carrera, Carrera 4, Carrera 4S, Targa)
We have installed many B&M shifters over the years, and they have proven to be one of the best when it comes to durability, and in fact we have never had to replace one. More likely, you have a cable or cable end issue. -
signalpuke started following Best short shift kit for 996
signalpuke replied to johnmh's topic in 996 Series (Carrera, Carrera 4, Carrera 4S, Targa)
I have a problem with my (I believe) B&M shifter, just started recently where it was getting difficult to shift into reverse. Now I can only shift into 2nd and 4th. What do I need to adjust and/or replace? I'm hoping it's just something simple, but I'm guessing the bushings need to be replaced? I just installed it a couple of years ago, and I tightened up the two side nuts (made it worse). -
986 Boxster S cranks but no start
Andrew Howell replied to Andrew Howell's topic in 986 Series (Boxster, Boxster S)
Just got the car started! I didn't realize that jumping the fuel pump relay bypasses the immobilizer. That makes a lot of sense now and got me thinking about what else could be cutting power to the fuel pump. Not much else in that equation so I went back over the basics again. I first checked for voltage at the fuel pump relay and confirmed that I did not see any voltage when cranking the car. Next down the line would be the fuse box so I looked at the fuse box again and went to pull the fuel pump fuse, a 25 amp fuse in position C4. I was shocked when I looked and it was completely missing! DOH! I did pull all the fuses about a week ago in a fit of desperation so perhaps I walked away with it to check for continuity or something and put it down somewhere? I have no idea where it went as its nowhere to be found in the car (apparently cannabis can effect the memory.) And that doesn't explain why it wasn't starting before I pulled the fuses. Perhaps the original CPS was bad as well? I tested the old fuel pump and it seems fine so my money is on that CPS. I guess I could put it back in the car to see if goes back to crank no start but at this point I'm very glad to have the car running. I have a car friend arriving tomorrow for a visit from across the country and the weather is perfect for some mountain and costal road carving with the top down. I was really worried that he was going to miss the opportunity to experience this amazing car that I've really been enjoying for the past few years. Thank you very much for the prompt responses, JFP. I couldn't have done it without your added info and I can't tell you how much I appreciate it! -
JFP in PA replied to Andrew Howell's topic in 986 Series (Boxster, Boxster S)
The immobilizer shuts off both the fuel and ignition systems to prevent theft of the car. The CPS does the same thing if it does not sense the engine rotation. When you jump the fuel pump relay, the immobilizer is out of the picture, so if you do not hear the pump running when it is jumped, you have a fuel pump issue. Using a multi meter or Power Probe, you can test the fuel up connector at the tank to see if it goes hot when cranking the engine. -
Abel Carranza changed their profile photo
Thanks for the quick reply, JFP. I have examined the immobilizer closely and there is no visible damage and both the fuses appear to be in tact. I still have the seat unbolted so I can check again but I even cleaned the connections with sand paper and alcohol just to be sure. I strongly suspect that the fuel pump is not getting power but I have not been able to confirm this. I have tried to jump the relay but I never hear any noise from the fuel tank when i turn the ignition to the on position. I tested the original pump that I removed from the car and confirmed it runs fine when I hook it directly to a battery. Perhaps there is another sensor that is keeping the immobilizer from sending power to the fuel pump? I have read about bad cam position sensors but I'm unsure if they will cause these symptoms. I'm thinking of looking there next maybe? Thanks again for the suggestions! -
JFP in PA started following 986 Boxster S cranks but no start
"I did see a message at one time while cranking saying the immobilizer was not in a ready state but I haven't been able to reproduce that message again." That is very concerning, that unit will paralyze the car if it is unhappy, so I would start there, pulling the unit and looking for evidence of corrosion, water damage, and check the glass fuse in the unit itself. - Earlier
Andrew Howell started following 986 Boxster S cranks but no start
Hello, I have a 2001 Boxster S 6-speed that left me stranded a few times and now refuses to start. There were two incidents where the car refused to start after running for a while so I first thought it was crank position sensor but then it refused to start at all so I thought maybe fuel pump. I have now replaced both the fuel pump and cps in the past two weeks but the car still refuses to start, just cranks. When i took out the old crank position sensor, it had a good amount of fine metal filings stuck to the end. Any thoughts where those came from? I'm quite sure the pressure plate has a crack in it but the clutch hasn't started slipping yet. When I installed the new crank position sensor, the car seemed to want to start and sort of puffed a few times but then just went back to cranking. When I turn the key to the on position I do see the tach raise up to about the 100 rpm marker and sit there while the car cranks, so I assume that is the "tach bounce" I've read about. I do have a durametric cable but I'm not seeing any obvious codes. I did see a message at one time while cranking saying the immobilizer was not in a ready state but I havn't been able to reproduce that message again. Any ideas or suggestions would be much appreciated. I'm feeling a bit defeated by this issue. Thank you in advance!
Try 2604
highnrg2 replied to pennyporsche's topic in Lost Radio Codes
May I please get a code for my Porsche Boxster 2000 Radio details: model BE-4462 S/N X5031767 Thank you kindly Highnrg2 -
Tiptronic works intermittently
STS replied to STS's topic in 996 Series (Carrera, Carrera 4, Carrera 4S, Targa)
Terrific. Thanks for the help! -
Loren replied to STS's topic in 996 Series (Carrera, Carrera 4, Carrera 4S, Targa)
Syid changed their profile photo
Loren, I am dropping my 2001 996 with Tip transmission off today to have the transmission serviced as you recommended before due to the Tip shifting working intermittently and not consistent. I am having a very hard time finding the Porsche recommended ATF for my 2001 996. Many searches end up talking about a manual transmission or a 996.2 instead of mine. Do you have any recommendations for a reference point or for the fluid? I read that Pelican is suggesting ATF 6. But someone mentioned that is not approved by Porsche and they are recommending due to Pentosin no longer producing ATF 1. I am amazed that it is so difficult to just search and find the proper ATF for a specific model. Any help or advice as to where I can search would be appreciated. Thanks, Todd -
I finally decided to just send my DME (ECU) into Specialized ECU Repair. BUT....along with ECU and Immobilizer they want the steering lock module which I believe is located above the steering column. Any hints on how to get at it. Service manual shows 2 long bolts at the top of the column then it looks like I can drop it down and remove the module. Thanks V
987 changed their profile photo
Darkblue started following depin x59 connector
do you know how to remove the socket side once you have the connector open? I tried pushing one out and it left behind a metal ring.
