All Activity
This stream auto-updates
  1. Past hour
  2. My apologies, missed a digit in the S/N. Below is the corrected S/N. BE2182 W5010609
  3. Today
  4. Like JFP said...take it to a pro. The compressors are pretty robust. It is the electro-magnetic clutch and friction plate that take a beating. One simple test is to engage the AC with the engine running and visually check the compressor to see if the pulley is spinning. Do not touch it with the engine running. In fact, check all the pulleys and belt at the same time.
  5. You risk major problems. If you are unsure how much oil is in the system, it can be flushed clean with a special solvent and than recharged from scratch, but that takes special equipment.
  6. Could be something as simple as a failed AC hose, or it could be the compressor itself. If you are not equipped to handle it, take it to a pro.
  7. Hi all. Was driving my 2003 996 cab 2 days ago. I heard a strange noise from the rear and pulled over. I smelled a burning type odor and a small amount of white smoke was coming from the trunk vents. Since that time the a/c is not producing cold air. Fan still produces plenty of air, but it isn't cold. Am I looking at a blown compressor here, or are there other possibilities? It gets rather warm in South Carolina, and sometimes rather than dropping the top I use the a/c. Any input from any of you would be greatly appreciated. Thank you in advance,
  8. Well, before I disconnected battery, I thought I wrote down what was the code. But it didn't work. So then I did the Tone-8-0 and got the serial number, which matches what was stamped on the side of the radio (labels were no longer there). Please provide the code for the following: BE2182 W501609 R3297 <-- 3297 is what I originally wrote down as the code, but apparently it isn't since it shows up when I electronically checked the serial number. Thanks! Kevin Atlanta, GA
  9. Thanks for the reply, Joe! As I understand the manual most of the oil remains in the system. Isn´t it too much, if I just fill up another 195g? What could happen, if I fill too much oil?
  10. On my Porsche Cayenne 2009 GTS got code P2404. After reading all the blogs, replaced the vacuum pump. It was the correct decision. Code went away and car runs better. You can change yourself if you have time and patience. Pump costs $160 online. Tools you'll need is small ratchet (https://www.amazon.com/Drive-Dual-Stubby-Ratchet-Handle/dp/B009TA14P2), E10 socket, string (attached to ratchet cause you'll drop it trying to squeeze it in position so easy to recover if you drop it), plier (disconnect the hoses). Pelican Parts website has good instructions on pump removal. Don't need to remove the intake manifold if you can squeeze hands where vacuum pump is located. Maybe an hour job.
  11. Hello, I too am faced with most likely replacing my catalytic converters on my 08 GTS with 128K miles. I have P0421 and P0431 codes. I already replaced all 4 O2 sensors, but the codes came back. So far, I've replaced thermostat, thermostat housing and updated the coolant lower pipe in the process as well. I've searched and ran out of other options on how to get rid of these codes. I'd appreciate any other suggestions or expertise anyone may have on this matter. If you could share some workshop instructions on performing this task, thank you.
  12. My 04 V8 has the P2187 and P2189 codes. It will start but runs only a few seconds and stalls. Would this be a PURGE VALVE issue?
  13. Yesterday
  14. Hello, My shifter became loose then came apart as I was backing her up in the yard. Anyway, I found a nut had come off and the pin itself was out of the mechanism. Then I saw that the ball joint for the cable, at the bottom of the stick was also off. I ordered the alignment part but I wound up judging by eye where it needed to be for the cable adjustment. (I saw some playing with one on youtube it was really easy to work with. (So far me and the car have had no real difficulties with basic repairs). I realized that the existing washers where a bit worn so I replaced them with some nylon washers. These were much larger in diameter. I also got two star washers but use only one. I saw that the nuts had a locking pattern on them but decided to use one on the nut that had come off. I also added a bit of blue thread lock to it for my peace of mind. The reason I am showing all this is because I want to hopefully remove some apprehension in doing these small repairs. It took me a while before I was comfortable working on my vehicles, but I still get professional advice. The top and bottom requires an allen key and 18 crescent. I forgot the size for the allen bit it was large. Anyway, here are the photos .... 😃
  15. The driver's side rear brake light on my car is working intermittently. When I first start the car, the brake light functions normally. As soon as I shift into gear, the brake light goes out and stays out (even if shifting back into park). I checked voltage going to the light fixture and there isn't any (to the brake light only). There are no error codes. Anyone familiar with the wiring that possibly their is some kind of control module going bad? It happens to consistently in the patter I described above to be a short in my opinion.
  16. I am needing some home. Just got my cayenne back from the mechanic, and for some reason it is still wet seems to be like hiccups when I go from 20 to 40. Just had new spark plugs and ignition coil’s installed, so I took it to the Porsche dealership and they’re telling me because the coils are aftermarket that can be the cause of the issue. I don’t know if I believe that if brand new ignition coil’s will cause misfire readings on all cylinders. And another thing I am attaching a picture and have circled an area in the engine that has a little cap. Now both sides of the engine have that same piece and should have a cap, when I look at my engine the passenger side does not have the cap on, Does anybody know what this is and what it does. I have circled in red .
  17. I have a 1999 RHD Carrea Convertible The electric windows work perfectly on switch, opening closing doors, on drivers key and 1 touch. But When you lower the roof the passenger window stays up all other windows lowerI If you now lower the passenger window from the switch so its down When you raise the roof the passenger window closes with the other windows Would this be a fault with the roof ECU not putting a signal out ? Where is the location of the roof ECU ? Does anyone have a copy of the roof wiring ? thanks
  18. RMS=rear main seal IMSB=bearing No such thing as a "RMS bearing" I would have them bleed the hydraulic system to the clutch slave cylinder again. No cable adjustments or other adjustments. Did they install the correct OE master cylinder? I have heard of some aftermarket master cylinders causing this exact problem. Did they install the upgraded versions of the release bearing and clutch fork?
  19. It's buried pretty deep. Lots of stuff to bolt/unbolt. I'd say it's more time consuming than difficult. I replaced mine when I replaced the vacuum lines since I had easy access at the time.
  20. I just had my clutch, pressure plate, release bearing, flywheel, master/slave cylinder and RMS bearing replaced on my Canadian 2000 996 C2 CAB. Now my pedal engages at the top of the travel (worse than my old worn clutch). Is this an adjustment (like the old cable adjustment) on the hydraulics or will my indie have to drop trans again?
  21. I have a used set of Bridgestone Blizzaks for 18" wheels I'd like to get rid of. Let me know if you want more details.
  22. Hi Steve, I hope you don't mind me sending you a message directly but sounded like that you've changed your fuel vent line (at the intake manifold as there seems to be about 3 with similar part description) and wanted to pick your brain.  The part number I need to replace is 996.110.129.06 (I've got a 2004 Boxster S Anniversary Edition).  Anyway, how difficult was it to do this yourself?  I've got minimal experience but have been able to replace my AOS and starter, is it much more difficult than that?
  23. Ah I see - the UK is a little more forgiving when it comes to this sort of thing. It also helps if you know the MOT tester 😏 With headlights, as long as you have the correct beam pattern and have it adjusted to the correct height - you are fine. The daft thing is, as long as you have the correct spec at the time of the test, you are then free to go home and change it back again!
  24. It is more than just glare, my license to conduct what you would call an MoT inspection requires me to fail cars with modified headlights or headlights components that lack our DOT approval marking. Police here can also require the vehicle be towed and repaired to factory specs before being allowed back on the roads.
  25. Since your system was completely empty, you have to go with the total technical data amounts, not just what is calculated for the condensers.
  1. Load more activity
