All Activity
This stream auto-updates
  1. Past hour
  2. Today
  3. My front right radiator has started running most of the time. Temp gauge reading is normal.Do you have any suggestions for the cause?
  4. E-bay Porsche trim clips, I just bought an assorted box of them. Cheap enough, remember Porsche don't make them, they probably buy them from E-bay too 😉
  5. No. If the code I gave you did not work then chances are that your radio was repaired by someone other than Becker. If that is the case then I can not help you... sorry.
  6. Plus -- no room for chains on 18 inch wheels.
  7. Hey Loren , I tried that code and it didn’t work , would you recommend a different ?
  8. The gauge cluster stores the odometer mileage, but in my mind nothing else. Why would it store the fuel level? Or maybe the last oil pressure reading and voltmeter reading? Makes no sense.
  9. thank you very much it worked
  10. Here are the original specifications. I would suggest not deviating from these for winter wheels and tires.
  11. Similar "problem" with my '04 Turbo -- was told to simply wait and let it warm up, rather than starting up and driving off right away.
  12. Also, does it matter how many mm offset I get? When ordering 18 inch rims I can choose an offset of 40 mm, 50 mm, or 53 mm for the front wheels, and 63 mm or 65 mm for the rear wheels. What does this refer to and is there a specific offset I need to order to fit my car?
  13. Hi Loren, Can you please help me getting my radio code. i have lost mine radio cod. Becker CR 220 BE4462 15075243 Regards
  14. Hi, I have a 2001 Carrera 4 Coupe and I want to put winter tires on it in the late fall this year. What size rims should I buy, 18 inch or 19 inch? What type of tires do you suggest?
  15. My dashbord with the 6 speeds on my cayenne turbo s 2003 dissapeared(blank screen),,,,,the car is in limp mode and the pwis is telling me is telling me a message that is the tiptronic control module,tcu...i checked every fuse...I removed de TCU from the passanger seat,clean it up and also borrow a 2nd hand one from a cayenne 4.5 ,no result blank screen,,,,my version of tcu is 09d927750aa and I replaced it for a test with a 09D927750AG software version S0310,btw PSM in diagnostic mode....and car is going only in 3rd gear think and R only making a BIG clunch sound when using the selector..it's running on reduce power and I cant see my speeds on display!!!!DO i need A virgin TCU tiptronic control unit!???so it can comunicate with my ECU!?The big problem is that nither PIWIS 2 3 cannot comunicate with the ecu it gives error OF SERIAL LINK Comunication on engine!!I repleced the battery reset the steering angle sensor!Tried everyting!!!Any ideea!?Thank you!
  16. Here's a link that I was planning to use as my starting point: Pelican Technical Article: Installing 997 Seats Into a 986 Boxster WWW.PELICANPARTS.COM In this article we'll show how to install 997 seats into a 986 Boxster Unfortunately, I was unable to purchase the seats (the seller was driving from Canada to Road Atlanta and I was planning to meet him in Roanoke. One of his companions was supposed to put the seats in his trailer, but forgot.) Therefore, I don't have any first-hand knowledge to share. I later found a set of seats (12-way driver, 8-way passenger) from a 996 Turbo that had been converted to a race car and installed them instead. I have attached the (rough) notes that I compiled before I changed plans and the 987 wiring diagram. I have some wiring and connectors from a 987 that I had planned to use in the project. Let me know if you think they will be useful. I recently adapted a set of Mercedes C63 AMG seats to work in the 2005 Mercedes C230 that I use as a daily driver. You can read about it here: Seat swap - 2009 C63 - MBWorld.org Forums MBWORLD.ORG C-Class (W203) - Seat swap - 2009 C63 - I will be meeting with a guy who is parting out a 2005 C230 some time this week. I need to replace the front wheel liners and I will also be looking to see if he has any trim that can upgrade some of my cosmetically challenged parts. The seller told me that... The seats in my Mercedes and Porsche work differently, but you may be able to glean something useful from my false starts and eventual (but delayed) completions of the project. I think you will be facing some of the same issues I encountered putting later generation seats into an earlier car. Because my C230 did not come with memory seats, I decided it would be too expensive and perhaps not technically feasible to make use of the memory function in the C63 seats. Mercedes uses a Canbus system to send data such as the signals that control seat memory. through out the car. If Porsche adopted a similar system, you may be in for quite a challenge. In addition to the seat motors, you will need to deal with the air-bag related seat occupancy sensor. If the 07 Caymans have the side impact air bags in the seats, you will need to ensure that you deal with them safely. If the seats are heated, that will be another challenge. Good luck with your project. Cayman seat info.pdf Cayman(987) 2006 Wiring Diagram - CU Seats.pdf
  17. Yesterday
  18. Sorry don’t have great reception to where I am sir , would appreciate the help though
  19. Really? Posting the same request 5 times? I think you need to wait another day or two - for breaking site rules.
  20. 1999 boxter Becker 1 Type 4462 Ser. X5023707 CDR -220 Need help with a radio code please
  21. Hey sir I have a boxter 2000 Becker 1 type :4462 ser: X5035834 WPOCA2971YU623565 cdr220
  22. And which contains multiple incorrect assumptions...……………..
  23. Yes, and MY200 Boxster. The radio also may have a separate in-line fuse. As well, the amp if you have one.
  1. Load more activity
