All Activity
This stream auto-updates
  1. Past hour
  2. i got some new codes this time p01362 and p01371 how can I Diagnose further with durametic
  3. Today
  4. Yesterday
  5. No. The vehicle would need to have the wiring harness for the module, and then be coded with a PIWIS to accept it before it would work. Can be done, but is rather expensive, which is why people go to the aftermarket systems.
  6. Brake flush, diff oil. Have the water pump looked at. On 986's, the water pump is popularly considered a maintenance item about every 5 years I think. And please make sure they know the right way to fill an empty cooling system if it's not a Porsche dealer. Some say they know, but a friend only got 20 minutes away from the service shop before his cooling system started puking due to trapped air. They didn't use an Airlift and didn't "burp" it either.
  7. Was out on the Pelican website, looking for some maintenance parts. Saw a listing for the TPMS control module. My 2006 Boxster S, manual didn't have that as an option. Was wondering if I bought the unit, installed it would the TPMS feature work, assuming I purchased tire sensors etc.
  8. Service advice needed. I have 2006 Boxster S, original owner etc. I only have 12k miles on it, the last maintenance I had was the 60K, dealer said although miles are low, its old, and that was most appropriate, that was done 2 years ago. I've just replaced the tires, spent $1300 & now am wondering what service should I get. Of course the dealer is recommending 80K service, plus a convertible top service, cooling system flush, transmission flush, alignment flush - all extras he suggested, all told $2900. Because of the new tires, i believe an alignment is in order, so no issue there with that.
  9. Hi. Why go back, is my first question? What head unit do you have? If you want to go back to Porsche head unit, you are talking big $$$$. My Boxster head unit doesnt spit out CD's, a rebuilt repalcement unit is around $3200 + installation. Plus it depends on how the current head unit was installed, wiring-wise? Do you have a Bose system?
  10. I would recommend doing the e-gas recalibration first, then verify fuel pressure. Note it's normal the fuel pump only turns on for about 1 second to prime the system at cranking. The fuel pump will keep running only if the engine fires up. That's a trivial safety feature.
  11. I concur with JFP. A smoke test is in order. Could be your evap canister has cracked due to age/mileage.
  12. No, don't have Durametric or any other tester. What is e-gas?
  13. Hi, the car was in a heated garage in a room temperature. So it is completely dry. We did, however, clean the floor mats with wet carpet cleaner. That thing has strong vacuum and do not leave the carpets really wet. No sings of rodent. When cranking rev counter rose to maybe 100 rpm. I guess my car was build in Germany - but not really studied the case
  14. So I've unsuccessfully been looking for a pic of how a carpet-less 986 looks like, but no luck. I.e., I'd appreciate if someone could give me a pointer. Besides, I''m also looking for a pic of how a stripped down (fully exposed) brake handle looks like -- without all the plastic. I just got those aluminum race floor-panels that I'm debating whether to install, in lieu of my soaked & stinky carpets, or not: (Btw, if anyone in SF bay area knows how to reset an immobilizer, please p.m. me) -- peer
  15. I just picked up a 2011 Cayenne S with faulty air suspension. I got it with the bladders fully deflated and assumed there was a leak, after jumping the pins on the compressor the suspension was able to air back up. I checked to make sure the 40 A fuse wasn't blown, no problems there. I assume it must be a bad relay, does anyone know where it is located? I cant seem to find any info regarding the relay...
  16. I also read about the metal “burp” clip being left up while running the car . - I know drivers of track cars have been known to do this .
  17. Last week
  18. Hi I have a Becker CDR-220 The Serial No is 15064360 Can someone get me the code? Thanks!
  19. Just get a genuine or Pierburg (OEM). Both use composite blades.
  20. For 986 boxsters - Has anyone got or has put together a list of water/coolant pumps by brand showing which have metal and which have plastic impellers ? It would be useful as so many here are saying don’t get a replacement with metal impeller . Thanks
  1. Load more activity
