All Activity
This stream auto-updates
  1. Today
  2. Thank you for the detailed response. However i wanted my spoiler permenently raised. I already sorted it by pulling D6. I just need to re-insert that fuse if i need to open the engine compartment. But its no big deal since i hardly ever need to access the engine.
  3. This worked twice for me over the years. Check D7 fuse and replace if bad (mine have been ok but this is a good place to start. Do an electrical system reset: Disconnect the battery negative terminal for 5 seconds or so and then reconnect it. Then try the rear-deck/spoiler raise/lower switch on the front of the fuse box (driver’s foot well area, press lower downside of switch in this case to manually lower the spoiler). Spoiler should lower normally and be ready for normal speed determined operation. Good luck!
  4. This worked twice for me over the years. Check D7 fuse and replace if bad (mine have been ok but this is a good place to start. Do an electrical system reset: Disconnect the battery negative terminal for 5 seconds or so and then reconnect it. Then try the rear-deck/spoiler raise/lower switch on the front of the fuse box (driver’s foot well area, press lower downside of switch in this case to manually lower the spoiler). Spoiler should lower normally and be ready for normal speed determined operation. Good luck!
  5. Battery went dead apparently. Lost code for radio. Becker / Type 4462 /Serial number is # 15004777 could you help please
  6. I sent my cluster to EZELECTRONICS they diagnosed an internal problem on the circuit board. Jose
  7. The LCD lights that backlight the odometer and temperature do not work on my 1999 Porsche Boxster. I changed to new light bulbs and they still don't work. Before dismantling the cluster and analyzing the circuit board I want to test to see if the lights are getting power. Does anyone know which harness and pins provide power to these 2 lights?
  8. Yesterday
  9. Thanks JFP in PA! 🙂 I contacted Porsche and they were kind enough to send it over. Looks like a PTS2 programming solution
  10. TSB's are the intellectual property of Porsche NA and cannot be reproduced or posted online as that would be a violation of their property rights.
  11. I'd also like to know. Need just one TSB #7239 How about a sticky topic at the top of the TSB section, or is it a secret special handshake only some can know about like Masons? 🙂
  12. I just discovered this scam, started on Craigslist, then leads you to Hollmann Group in Michigan. It is very eloborate with convincing website and reviews! Here is a copy of email I received that has also been documented on rennlist as well. Reason for post is they claim to move alot of pacts.
  13. Any help for my 01’ Carrera Radio CDR 220 serial # 15064383 Had my convertible top repaired and apparently they disconnected the battery.
  14. Last week
  15. CR210 BE2182 Serial: V5005059 Ty!
  16. Worked like a champ. Thanks so much, Loren!
  17. I have a 2001 with 49k and use Lucas upper cylinder lube with every tank fill up
  18. Thank you, I will try this. Will it help to push on the A pillar or windshield etc while driving?
  19. Get a passenger. Put a cell phone in video mode and run it all over the dash and underneath while driving. Pay particular attention to the A-pillar on the passenger side.
  20. Still no luck, this thing has got me crazy 🙄
  21. I’m brand new to this site and hope you all can help me with I believe is a dash rattle on the right side of my dash towards the windshield. I have a 2001 Carrera 911 cabriolet with 49,000 miles on it. I cannot seem to locate where this rattle is coming from. Does anybody have any words of wisdom on this matter?
  22. Anyone Install a Remote Starter on their 958.1? - Rennlist - Porsche Discussion Forums RENNLIST.COM Cayenne 958 - 2011-2018 - Anyone Install a Remote Starter on their 958.1? - I just brought home a new-to-me, CPO'd 2012 Cayenne S as my winter DD. The only way I got my wife comfortable with me buying what is now my 3rd Porsche was by promising that her '14 Audi Q7 would always be parked inside in Winter next to my...
  23. Thanks for the info. I wish I would have seen the suggestions about the oil filter adapter before I changed the oil. Maybe next time. It was something I considered when looking for a new filter and canister.
  1. Load more activity
