All Activity
This stream auto-updates
  1. Past hour
  2. I made some progress too...the trick to reattaching the fuel line is to do it before the intake manifold is bolted back in, so as to have just enough wiggle room to get the fittings in tight and secure. Then, tighten the intake M1O bolts. I was doing well until an M10 bolt fell into the engine, now I can’ find it. This project has been a curse that I wish I never put upon myself...
  3. Today
  4. I attempted to upload some photos, but the site would not allow it. There is way way more room, and you can see everything easily. So, it is certainly more work, but I think in the end it will be less time, and hopefully remove some of the massive hangups people have been hitting. I am going to attempt to replace the coolant tee, since I removed all the lines anyway.
  5. I made progress today, but it meant a lot more work. I drained the coolant and removed the alternator. I also removed most of the high pressure fuel pump lines, but that didnt seem to be necessary. With the alternator and coolant lines out of the way, I was pretty quickly able to put the top side of the curved fuel line into the seat of the top rail. Then like the write up, I had enough room to reach under it and get the fuel rail back through the intake manifold. I did have to pitch the manifold up toward the driver side to get the right angle, but everything went back together with that little bit more room to operate.
  6. Hi DK570, how many miles do they have on them?
  7. This is what I have in mind. I thought I would get a set, because as these cars are getting older it might be harder to get them. I know you can always order all the parts, but the price will be the question. Sent from my iPhone using Tapatalk
  8. My shift pattern emblem was taken from my 996C, hopefully by someone who can use it on their own Porsche. ‘Regardless, can someone help with where a replacement can be found. A plain plastic insert will work as well as one with a pattern or symbol. The thought of replacing the shifter with a solid billet with engraved pattern has crossed my mind, so I would also appreciate any input concerning that. I thank you in advance for any help. Steve
  9. *** update *** after writing my previous post, I pulled fuse number 8 (in engine bay) and the noise stopped. Put the fuse back in and the annoying sound returned. Out again and the sound stopped. Fuse 8 controls ‘Tank vent valve “ and a few other things. I guess I have a faulty tank vent valve. Now I need to figure out how to get to it and replace it.....
  10. Thanks Loren. After some more research, I thought of pulling the fuel pump fuses to see if the noise is coming from either of the two fuel pumps. It’s not. I pulled fuse 13 first, the noise remained and the car stalled after about 15 seconds. I put fuse 13 back in, started the car, waited for the sound to start again which it did after idling for about a minute, then I pulled out fuse 14. The engine kept running but the sound still remained. Listening to it some more today, it sounds like a vacuum valve or some sort of a vacuum related sound. My car does not have the exhaust/muffler valves that activate in sports mode. Is there any other vacuum valve or something similar in the tank?
  11. Please help...Just curious if someone can help me identify the ports I have circled in the pics I attached. I'm assuming they would be for antenna, XM etc. Just want the exact diagram. I installed an aftermarket radio and I know I don't have the BOSE sound system but I'm curious if one of those connections are for an amp. I'm not getting any sound out of my new radio.
  12. Yesterday
  13. Hi Jonhattan, I am in the exact same place you are. I reinstalled the intake and all went well except for that stupid flare fitted solid line which connects the lower fuel rail to the fuel pump. I spent the entire day trying to retighten those two fittings, and got fuel leak each time, either on pump side or lower rail side. There is zero space to work there, so I can only use two fingers, and had to grind a wrench to make it fit there. I bent the hard line to make it fit better, but maybe that was a mistake... I also thought about making a flexible high pressure line to make the job easier. Let me know if you go that route or where up you end up. So close...It almost feels like this was designed by some sadistic German engineer to torture people trying to work on their Cayenne. Aurelien
  14. Check and make sure one of the tires is not making contact while turning and backing up.
  15. I have one of those situations where the car shows symptoms of a problem when cold that can’t be duplicated when later warmed and at the repair shop. Here’s what’s happening. With my 02 C2 cab nearing 140K miles, it was time to have struts replaced again and for the first time, attend do all the little squeaks and knocks coming from tired suspension components. Up front I now have new: front control arms (lower and trailing), coil-over struts and top mounts, sway bar drop links and bushings, and inner and outer tie rods. I thought I was set for years to come but something new has cropped up. When the car is backed up with steering hard left, I experience three or four pronounced "snatches" or ‘grabs" coming from the front left. The steering wheel jumps and I feel a series of rapid bumps through the seat. Ease off the left turn and all is smooth again. It only happens when the car is cool. The snatching does not happen when backing hard right or when the car is stationary and the steering wheel run to and fro. Even though I’ve gotten in the habit of not steering near hard left first thing in the morning, I think I should have this sorted out. It would be good if I could point my shop in the right direction so if anyone has a cue to tell them it, would be much appreciated.
  16. The correct filter for an early 996 is the 986-307-403-00, which was also used in the Boxster.
  17. Does anyone know the part number for the frunk light micro switch? The part number in the tutorial does not fit the '98 Boxster. Thanks!
  18. Yes, I think you would be best to get a diagnostic scan with a Porsche tester. Any good independent will have the equipment.
  19. Take a moment to remember the sacrifice of those that made what ever you are enjoying possible...…..
  20. Is the filter on an early 996 the same as the filter on a 986? The part numbers listed in the guide are 986.xxx.xxx.xx... Which is great because they're half the price of the 996.xxx. Parts, but that seems a bit odd if they are identical.
  21. Coolant sensor #27 here M96.01/02/03 Oil Pump M96.04 WWW.AUTOATLANTA.COM
  22. Just tell them you have swapped clusters, they should be able to take it from there.
  23. Get the car scanned with a Porsche specific scan tool (Durametric or PIWIS), the system stores the last 10 alarm faults and will point you to the problem.
  24. 97 boxster all stock. I used my key to unlock the car and now I got problems.... I am not sure but I think this is the part that needs to be replaced. I am getting two beeps and sometimes one. I fixed the center lock when I fixed the stick shift. I thought maybe the center glove box might be contributing to the problem but it is not. I am not sure if I need this: 1997 Porsche Boxster Base Convertible - Electrical - Switches, Motors, Relays, Fuses & Wiring - Door Switches, HVAC Motors, Relays, and Switches, Starters, Window Motors and Relays WWW.PELICANPARTS.COM Switches, Motors, Relays, Fuses & Wiring for 1997 Porsche Boxster Base Convertible: Door Switches, HVAC Motors, Relays, and Switches, Starters, Window Motors and Relays or This: 1997 Porsche Boxster Base Convertible - Electrical - Switches, Motors, Relays, Fuses & Wiring - Door Switches, HVAC Motors, Relays, and Switches, Starters, Window Motors and Relays WWW.PELICANPARTS.COM Switches, Motors, Relays, Fuses & Wiring for 1997 Porsche Boxster Base Convertible: Door Switches, HVAC Motors, Relays, and Switches, Starters, Window Motors and Relays
  25. I would use a working bulb in the one that is not working....it is too much of a pain finding a meter. Your best tool is a bulb that works. =D
  1. Load more activity
