dear members,
my car is one and half year old. if i'm right, i remember being able to
see the coolant through its plastic shell as blue/green.
my car doesn't go out a lot; i was unable to drive for quite long and she stayed
in the garage; as i'm back and drive it again, i noticed that the coolant's colour
tend to look green/yellow through the plastic container.
i'm not strong enough to open the container for now :( and can't tell you
exactly what the colour is.
Anyway, I would be curious to know if the colour mutation is normal, from
this blue to a yellow/green. Knowing that in theory, the liquid doesn't have
to be changed, I find this disturbing. :help:
thank you to let me know what you've experienced
zach
Edited by zacharie
Thank you for the photos Tool Pants. It's interesting to see the degradation of those colours.
I hope the coolant fluid keeps its function, I mean the whole chemistry of the fluid remains
intact; if I am correct, the coolant lifetime is supposed to be equal to the car's. Still, I wonder...
Edited by zacharie
The Porsche service manual says:
The engine cooling system is factory-filled with a coolant which does not need to be changed. The coolant should not be mixed with other coolants.
Only Original Porsche anti-freeze should be used when changing or topping up the coolant.
Hi Loren,
Thank you for your very accurate extract. I was on the verge to change the coolant... :notworthy:
