What shift knob should I get - 5 speed 986 ?
Hi guys,
I am getting ready to do the B&M short shift install in my 01 Boxster and I noticed that my shift knob and boot are a little worn-out.
I was wondering if you guys have any suggestions on what I could get to replace the OEM one. I know from Chris_NH that there is a very nice aluminum shift knob from Porsche, which he has in his car (option # Y06, part number x97). Unfortunately there isn't anyone available on Ebay right now and a new one will cost around $350 from Sunset!
My car is a 5-speed which makes it a little harder to find anything.
Gus
Edited by gandrade1
Hi Juniinc,
I had selected exactly the carbon fiber Momo that you pointed out and what they call the Endurance boot.
But I read that Momos don't fit the Boxster unless a lot is modified. Will that change when the shifter is replaced by the B&M?
This is the set I chose:
Knob
Boot
Mounting Ring
Best,
Gus
Hey, grandrade sup? great choice by the way
I don't think much will change when its replaced with a B&M shifter. Porsche uses a flat shift lever unlike some 14mm threaded European cars so is B&M
Throwing a short shifter in Ur car would be way more work than replacing your knob I think.
First mod would have to be our 986 manual shift knob being 1 piece with its leather boot. So whenever we tried to throw one of these universal knob, a little mod is required? Probably the biggest reason most ppl go for the 1 piece replacement.
I checked out your Momo endurance finisher & I don't see how U can possibly make that boot work/look good with that thing being just elastic base, then again I never seen this thing yet.
If I was doing this job, I would try to re- utilize your OEM leather boot so it fits around your center console like its supposed to,,,then figure out how to secure the knob - I'm sure that would be the easiest part for u
I found 1 of TP's old pics in here, I'm hoping that he doesn't mind ;)
Hi Juniinc,
Knob
Boot
Mounting Ring
Best,
Gus
Edited by juniinc
Great feedback, guys!
Do u guys have any idea whether I can buy only that plastic frame that goes around the boot (in the bottom) from Porsche?
...Otherwise I could try to buy any beaten up Boxster knob/boot on Ebay and try to somehow glue the new (Momo) boot to the frame I remove from the old Ebay boot. I intend to keep the OEM knob/boot that is coming out of my car, because when I upgrade the car (one day) I intend to convert it back to the OEM shifter and knob.
Best,
Gus
eagle day sells just the leather boot(available in diff color)for about $85.00. TP also said U might be able to find some at Gert Stills.
Hi Juniinc,
How are you?
As promised I posted my experience with my first DE training this weekend under a new topic DE Experience. With some questions - just for a change...Hahahaahah
Coming back to the Knob/Boot issue, I check eagleday.com, but it seems they only sell the entired set (boot+knob) for the Boxster, for $235. I could not find Gert Stills.
Any other idea?
Thank you very much,
Gus
Edited by gandrade1
Hey Gus, I'm good & sup?
U will be able to find a knob + colored leather boot for $89.95 at Eagleday.com.
I think that's gonna be your best bet
Hi Juniinc,
How are you?
Any other idea?
Gus
Hi Juniinc,
I ordered exactly that part (in black) and got it on Monday... It looks a little 'old-fashioned' compared to the one I currently have (like the one K.Brandsma posted above).
I was thinking about returning the part, specially because I need to order the 'shift pattern' emblem and I could not find anyone that looks nice - was looking for an aluminum one (5 speed), but all I could find were the ones in eagleday.com
Not sure what the alternative is... I really wanted to go for the Momo knob (carbon fiber look), but see no way to attach it to my shifter. The Momo has a round shape and, despite having several 'rubber rings' to adapt the knob to shifters with different diameters, I bet none of them will fit our oddily shaped shifter.
If you have any other idea, please let me know.
Best
Gus
Edited by gandrade1
I agree carbon knob will look awsome.
We usually take a band- saw , cut/shape the flat blade shift lever to fit,,,
I don't know perhaps it's just me, but I'd like my 986 to be unique in its way so it easily seperates from the others.
good luck ,GUS
Hi Juniinc,
Best
Gus
Hi Gus,
I recently did a short shift upgrade and used the eBay shifter.
Does anyone know the Porsche part number on this shift knob?
And does it come with only the knob or also the leather boot?
