Leaderboard
Popular Content
Showing content with the highest reputation on 04/07/2018 in all areas
  1. Have you removed and cleaned your throttle body? This needs to be done probably yearly. Also, carefully remove the cold start valve (do not lose the paper gasket - or replace if damaged) and clean it so it moves freely.
    1 point
  2. Top View 1- Ignition bar module, cylinder 1, bank 1 2 - Ignition bar module, cylinder 2, bank 1 3 - Ignition bar module, cylinder 3, bank 1 4 - Ignition bar module, cylinder 4, bank 1 5 - Ignition bar module, cylinder 5, bank 2 6 - Ignition bar module, cylinder 6, bank 2 7 - Ignition bar module, cylinder 7, bank 2 8 - Ignition bar module, cylinder 8, bank 2 9 - Fuel injector, cylinder 1, bank 1 (hidden) 10 - Fuel injector, cylinder 2, bank 1 (hidden) 11 - Fuel injector, cylinder 3, bank 1 (hidden) 12 - Fuel injector, cylinder 4, bank 1 (hidden) 13 - Fuel injector, cylinder 5, bank 2 (hidden) 14 - Fuel injector, cylinder 6, bank 2 (hidden) 15 - Fuel injector, cylinder 7, bank 2 (hidden) 16 - Fuel injector, cylinder 8, bank 2 (hidden) 17 - Inlet camshaft hall sensor, bank 1 18 - Inlet camshaft hall sensor, bank 2 19 - Knock sensor, bank 1 (hidden) 20 - Knock sensor, bank 2 (hidden) 21 - VarioCam solenoid valve, bank 1 22 - VarioCam solenoid valve, bank 2 23 - Ambient air solenoid valve 24 - Positive crankcase ventilation 25 - Three-way pressure valve 26 - Tank vent valve 27 - Throttle adjusting unit 28 - Positive crankcase ventilation heater 29 - Boost pressure control solenoid valve Front View 1 - Mass air flow sensor, right (hidden) 2 - Mass air flow sensor, left 3 - Charge air cooler, right 4 - Charge air cooler, left 5 - Boost-pressure sensor 6 - Boost pressure control solenoid valve (hidden) 7 - Boost pressure control valve (waste gate) - mechanical, right 8 - Boost pressure control valve (waste gate) - mechanical, left (hidden) 9 - Vacuum accumulator (in intake distributor) 10 - Overrun recirculating air solenoid valve (hidden) 11 - Overrun recirculating air valve - mechanical, left 12 - Overrun recirculating air valve - mechanical, right Rear View 1 - Secondary air valve - mechanical, left 2 - Ambient air solenoid valve 3 - Vacuum accumulator - integrated into intake distributor 4 - Coolant temperature sensor 5 - Secondary air valve - mechanical, right Underside View 1- Oil level and temperature sensor Oxygen Sensing 1- DME control module 2 - Secondary air injection pump, bank 1 3 - Secondary air valve - mechanical, bank 1 4 - Oxygen sensor in front of catalytic converter, bank 1 5 - Pre-catalytic converter, bank 1 6 - Oxygen sensor after catalytic converter, bank 1 7 - Main catalytic converter, bank 1 8 - Secondary air injection pump, bank 2 9 - Secondary air valve - mechanical, bank 2 10 - E-box in radiator tank with fuse and relay carrier 11 - Main catalytic converter, bank 2 12 - Oxygen sensor after catalytic converter, bank 2 13 - Pre-catalytic converter, bank 2 14 - Oxygen sensor ahead of catalytic converter, bank 2 Charge Measurement and Fuel Supply 1 - Mass air flow sensor, right 2 - Fuel injector, cylinder 1, bank 1 3 - Fuel injector, cylinder 2, bank 1 4 - Fuel injector, cylinder 3, bank 1 5 - Fuel injector, cylinder 4, bank 1 6 - DME control module 7 - Electric fuel pump, right 8 - EVAP canister 9 - Fuel tank 10 - Electric fuel pump, left 11 - Driver's door lock with switch for fuel pump supply 12 - Current distributor with cutoff relay under driver's seat 13 - KESSY control module 14 - E-box in radiator tank with fuse and relay carrier 15 - Pedal sensor 16 - Fuel injector, cylinder 8, bank 2 17 - Fuel injector, cylinder 7, bank 2 18 - Fuel injector, cylinder 6, bank 2 19 - Fuel injector, cylinder 5, bank 2 20 - Tank vent valve 21 - Mass air flow sensor, left 22 - Positive crankcase ventilation heater 23 - Throttle adjusting unit Charge Measurement and Fuel Supply - additional items for Turbo 1 - Mass air flow sensor, right 2 - Overrun recirculating air valve - mechanical, right 3 - Turbocharger with boost pressure control valve (waste gate), right 4 - Boost-pressure sensor 5 - Boost pressure control solenoid valve 6 - Vacuum pump for brake booster 7 - Intake distributor with integrated vacuum reservoir (used to control overrun recirculating air valves, for example) 8 - DME control module 9 - Brake booster 10 - E-box in radiator tank with fuse and relay carrier 11 - Pressure sensor for brake booster 12 - Ambient air solenoid valve 13 - Turbocharger with boost pressure control valve (waste gate), left 14 - Overrun recirculating air valve - mechanical, left Camshaft and Ignition Sensors 1 - Inlet camshaft vane-type adjuster, bank 1 2 - VarioCam solenoid valve, bank 1 3 - Ignition bar module, cylinder 1, bank 1 4 - Ignition bar module, cylinder 2, bank 1 5 - Ignition bar module, cylinder 3, bank 1 6 - Ignition bar module, cylinder 4, bank 1 7 - DME control module 8 - Hall sensor, bank 1 9 - Hall sensor, bank 2 10 - Ignition bar module, cylinder 8, bank 2 11 - Ignition bar module, cylinder 7, bank 2 12 - Ignition bar module, cylinder 6, bank 2 13 - Ignition bar module, cylinder 5, bank 2 14 - VarioCam solenoid valve, bank 2 15 - Inlet camshaft vane-type adjuster, bank 2 16 - Knock sensor, bank 2 17 - Knock sensor, bank 1 Temperature Control with Sensors 1 - Radiator fan, large (right) 2 - Ambient air temperature sensor 3 - Thermostat with housing 4 - Coolant temperature sensor 5 - DME control module 6 - Instrument cluster 7 - E-box in radiator tank with fuse and relay carrier 8 - Additional coolant circulation pump (also controlled by the DME in turbo engines only) 9 - Radiator fan, small (left)
    1 point
