Leaderboard
Popular Content
Showing content with the highest reputation on 09/19/2018 in all areas
  1. 991 S (both C2S and C4S) Front new: 34 mm minimum (after machining): 32.6 mm wear limit: 32.0 mm Rear new: 28 mm minimum (after machining): 26.6 mm wear limit: 26.0 mm
    1 point
  2. Vincent, I just got her running and it was the Pulse Sender (aka Crankshaft Position Sensor) and it is called a "Impulse sender" at Pelican Parts. Odd I had no faults on the Durametric? Item Name Item Price Quantity Item Total --------- ---------- -------- ---------- 986-606-112-02-M14 $131.75 1 $131.75 Impulse Sender, Boxster 986 (1997-2004), Brand: Bosch -m
    1 point
  3. Consider a faulty crakshaft position sensor. If these overheat, they can fail, not allowing the car to start, but temporarily come "back to life" after the engine cools down a bit.
    1 point
