Leaderboard
Popular Content
Showing content with the highest reputation on 01/14/2019 in all areas
  1. How does the car run on the left pump only? Remove fuse from right pump and cycle ignition off and back on. If the car runs good on left pump but bad on right pump, you can almost guarantee the right pump, inside tank piping issue, or power to the right pump is the issue. You could also swap the fuses and relays to rule out that as a problem.
    1 point
