Leaderboard
Popular Content
Showing content with the highest reputation on 05/27/2020 in all areas
  1. A couple of days ago my head unit started cycling off and on every minute or so. I found some posts that these things are notorious for failing so I started looking for a place that would repair it. Luckily I found the Becker office in Saddle Brook NJ, called them, and they emailed me instructions how to fix it. Apparently my XM SAT provider caused the problem. It required a reboot as per below: WARNING It was brought to our attention, that the PCM 3.0 and 3.1 units have been rebooting continuously on a number of Porsche vehicles at the moment. It seems that a signal was sent by SiriusXM which has caused this issue. SiriusXM and Porsche are investigating currently and are working on a fix. VERY Important: Please DO NOT replace any parts or hardware on a vehicle, due to this issue. In order to rectify this issue, you will perform a “PCM handover” (also known as a PCM Hard Reset). Instructions are listed below; Press and hold the PCM>>Info button for approximately 10 seconds until the PCM reboots. Immediately select the following from the PCM; CAR>>OPTION>>Set PCM System>>Reset PCM>>Vehicle Handover>>Yes>>Yes These instructions can also be found in the respective Owner’s Manuals for affected vehicles. Hopefully this may prevent Dealership / workshop visits. If your vehicle is already at the workshop, recommend that the technician update it to the latest available software level. **PLEASE NOTE: Performing a PCM Hard Reset will also erase all of the radio presets and Bluetooth connections and these will have to be reentered by you after the reset.** In order to rectify this issue, you will perform a “PCM handover” (also known as a PCM Hard Reset). Instructions are listed below; Press and hold the PCM>>Info button for approximately 10 seconds until the PCM reboots. Immediately select the following from the PCM; CAR>>OPTION>>Set PCM System>>Reset PCM>>Vehicle Handover>>Yes>>Yes WARNING Reboot for PCM 3.1.docx WARNING Reboot for PCM 3.1.pdf
    1 point
