Leaderboard
Popular Content
Showing content with the highest reputation on 11/22/2020 in all areas
  1. If you have done 90k km or multiples of the the cardon shaft bearing need replacing before it costs you a whole shaft. Easy to check, get a small wreaking bar and move the shaft up and down, if you see cracks in the rubber around the bearing then replace it now!
    1 point
  2. Thud could be centre bearing carrier for the rear cardon shaft. Whistle may be evident if your aircon servo flaps are closed. Try opening them by turning on the fan and having air flowing to the outlets.
    1 point
