Leaderboard
Popular Content
Showing content with the highest reputation on 12/01/2020 in all areas
  1. Sorry for the delay, but the Virus has made things upside down everywhere around New York. Hope it's not too bad in Cleveland.:) I think I found some initial pics that can help you get started in solving the problem with your top... Here is a series of photos on my '97 Boxster when it still had the original "A Version", all metal housing transmissions. I think that if you put your clamshell manually to this exact position, and then duplicate the position of the V-levers and other parts, you will have an excellent starting point. Forgot to mention what the red arrow and the yellow arrow are pointing to in the last photo posted(367.38 kB)..Red is pointing to the "fat washer" under the 10mm bolt which in turn holds down the small flat bushing/sleeve (Yellow arrow pointing to joint) that keeps the overall length of the pushrod in its set position. Of course that has a major effect on the position/attitude that the leading edge of the convertible top will have when it is in its pre-latching (or immediately post-latching) position. A relatively tiny difference in overall length will also have a relatively drastic effect on whether that "final" position ends up correctly aligned or whether the leading edge of the top goes past its forwardmost position and then starts to retract...then making it impossible to latch the top securely. To achieve a finer adjustment, don't loosen the 10mm with fat washer, use each 360 degree turn or rotation of the plastic ball cup on the forward end of the pushrod to change the overall length of the pushrod. Let me know if that works, otherwise I can look for some more. Regards, Maurice.
    1 point
  2. Palo Alto Speedometer did the mileage change. They charged $150.00 and did a great, two day turn around. And, paspeedo.com was very responsive to my e-mails. I have seen some of the recycling yards asking up to $400.00! Unfortunately, the shipping was almost as expensive as the service: $60.00 each way. I insured the instrument cluster for full replacement value and the carrriers, UPS out, FedEx back, required second day delivery......I suppose to limit the exposure to the twenty foot drop test some boxes get. Here is a look at the cost of the project: :eek: 1. Carrera instrument cluster: $350.00 2. Carrera oil pressure sensor: $ 43.17 3. VW Wire Pin: $ 3.56 4. Mileage reset: $150.00 5. Shipping: $120.00 6. Radio Shack purchases: $ 7.00 7. Porsche dealer assistance: $122.00 Cheers, Bill
    1 point
