Leaderboard
Popular Content
Showing content with the highest reputation on 10/25/2018 in all areas
  1. 1 point
    Hi ehostin,There is absolutely no reason to pull your wheel well apart. Go back to your fuse box and pull out the red trunk lid lug. It will pull out almost an inch exposing a copper contact. Using any high current 12 VDC source like a 12 volt motorcycle battery or the battery in another car, hook the negative post to any ground on the car. The metal door stop between the door hinges is handy. Hook the positive terminal to the red lug and give the trunk release switch a pull. BINGO. You can use any jumper cable. Get a new battery for your car. Once you deep cycle them like this they are junk.
  • RennTech.org Store at Amazon.com
  • Newsletter
    Want to keep up to date with all our latest news and information?
    Sign Up
