Leaderboard
Popular Content
Showing content with the highest reputation on 03/11/2019 in all areas
  1. 1 point
    Not necessarily, modules sometimes have to be recoded and they come back online, but not always. Sometimes they are just dead.
  2. 1 point
    In a word, no. It requires a PIWIS system.
  3. 1 point
    Welcome to RennTech I would ask your tech how he determined the AOS is bad, and what does he base his RMS/IMS seal leakage upon. 20 hours is excessive, more like 8-10 hours is realistic to pull the Tip and replace both the AOS and either the RMS or IMS seals. I would also check with another Porsche oriented shop for a second opinion.
  4. 1 point
    I have had this show up my both my CGTS and GT4. Much ado about nothing as far as I can tell. I have drained oil off by loosening the filter, or just let it go. Done several track weekends with the alert notice on. Problem is not simply overfilling, but under-draining by the car, imho. Sent from my iPad using Tapatalk
  5. 1 point
    Don't you just love these dipstick-less cars designed for millennials? On my first oil change, I over-filled it by 1.25 liters all due to the fact I did not fully understand the Oil Measurement Display. I thought the MAX level was at the top of the bar, which it isn't. The MAX level is shown in A below. Anyway, I just drained it and the level is at MAX. I also would not use a vacuum pump for the reasons mentioned.
  6. 1 point
    P0171 Oxygen Sensing Adaptation, Idle Range, Bank 1 – Above Limit P0174 Oxygen Sensing Adaptation, Idle Range, Bank 2 – Above Limit Possible fault causes: - Incorrect signal from MAF sensor - Intake air system leaking - Fuel pressure too low - Volume supply of fuel pump too low - Fuel injectors fouled - PCV valve leaks - Cap of oil filler neck not closed correctly or seal is damaged Looks like you have a leak...
  • RennTech.org Store at Amazon.com
  • Newsletter
    Want to keep up to date with all our latest news and information?
    Sign Up
