Click here to Donate
Leaderboard
Popular Content
Showing content with the highest reputation on 04/29/2019 in all areas
  1. 1 point
    Yes, I agree...I will buy one from the dealer next and see if there is any noticeable difference.
  2. 1 point
    I would say the top unit is a knock off. We have had absolutely no luck with aftermarket AOS units, some even failing right out of the box. Considering how annoying they can be to swap out, it ain’t worth the price differential.
  3. 1 point
    After a few emails and a couple of phone conversations, I have decided to send my car to Flat 6 Innovations. Jake believes it is a broken chain (he has seen these symptoms many times) and I tend to agree. Hopefully I don't have any piston damage and I will get the car back in a few weeks. But if there is piston damage I would get an entire engine reconstruction which takes 8 to 10 months... Although a Raby rebuild would be nice.
  4. 1 point
    When somebody takes good care of their car, there is little that can be said in a situation such as that other than commiserations. I wish you good luck.
  5. 1 point
    Well... I jacked-up the car to inspect and as I was jacking I saw two drops of oil. Thinking to myself maybe the bracket holding the solenoid broke (I read that somewhere on one of the forums), something simple. But when I got under the vehicle there was quite a bit of oil on the front of the cam cover (nearest the passenger compartment). Closer inspection I discovered the cam cover is cracked near the top probably a couple inches long. I have a major issue (possibly broken cam). Now I need to decide how to replace the motor... Rebuild, salvage, new, Jake Raby. Wish me luck. My wife asked, "how could this happen? You take car of your cars and don't abuse them." My reply... "things break".
  6. 1 point
    997 Turbo Bumper removal, Radiator cleaning, and Mesh Grill Install: Removed front bumper assembly, cleaned radiators, and fabricated and installed new aluminum mesh grills to block some of the trash. Took photos, and documented the process I used and created a simple do-it-yourself website. I am no expert, and I am sure there are many ways of doing this..So if it helps, Great! If you know a better way...go for it. TheRocksFront MeshGrillsDIY.pdf
  • RennTech.org Store at Amazon.com
  • Newsletter
    Want to keep up to date with all our latest news and information?
    Sign Up
