Click here to Donate
Leaderboard
Popular Content
Showing content with the highest reputation on 08/22/2019 in all areas
  1. Product ID : 1056 327 173 01 Sent from my iPhone using Tapatalk
    1 point
  2. I have had my '84 Carrerra for six years. It is a second owner car that I cherish. In January 09, we moved from SoCal to Omaha, NE. When the car was transported out here, I began having shifting/grinding problems with the 915 box. I checked several local "Porsche" shops before finding FLATSIX in Bloominton MN. Aaron Hatz is the owner/technician. I, of course, assumed the worst and agreed to have him rebuild the transmission. He drove down to Omaha with his enclosed trailer and took the car back to MN. A few days later, he called me and said he had found the problem. Turns out that se
    1 point
  3. Have recently completed adjustments on clutch cable as well as on the foot pedal. Gears had improved, but suddenly yesterday, I had a great deal of difficulty in lining up 1st and 2nd gear. It was as though they weren't there. No problem finding 3rd / 4th and 5th and Reverse. Initially I thought that the shift coupling between the rear seats had slipped, but it was still tight. I followed the instructions on how to Improve Shifting off the Pelican Site (same as in my Bentley Manual), by loosening the clamp, rotating the coupler counter-clockwise looking to the rear of the car, and the shi
    1 point
  4. Ok guys, you've been waiting for this, and as promised, here is my brief, but descriptive walkthrough. this is what you will need as the following: Porsche Panel wedge tool Screw Driver w/ T-20 bit and Flat head bit Turbo Instrument Cluster strong fingers! Ok with that cleared away, here is the first step. Remove the black plastic gauge cover above the gauges. Use the wedge tool or , in this case I used my fingers! (don't use the fingers, i highly recomend not to , it hurts hahahah). Remember , you will need to apply gentle but enough pressure to detach the tabs off from the top
    1 point
  • RennTech.org Store at Amazon.com
  • Newsletter
    Want to keep up to date with all our latest news and information?
    Sign Up
