Click here to Donate
Leaderboard
Popular Content
Showing content with the highest reputation on 01/12/2020 in all areas
  1. Becker radio sticky knob fix. I actually performed this fix on my radio knobs about 3 months ago, but did not want to post anything until I know it is capable of surviving the 90+ heat wave we get here in DC. Well the fix helded up with not degradation in the appearance, texture, and feel so here is what I did. (sorry no pics of the painting) 1. Remove knobs from the radio by pulling the knobs straight out 2. If the knob have been textured from prior attempts to clean the gummy dissolved rubber off the knobs, gently rub/press/massage the knob to remove/smooth as much of the
    1 point
  2. I had heard this urban legend that you can repair door dings and dents by rubbing dry ice over the dent and then heating it with a hair dryer or heat gun. It seemed simple enough, so I decided to try it on the wife's urban assault vehicle which has its fair share of door dings. I went over to our neighborhood grocery store and got 2 pounds of dry ice for $3. Here is the what the test door looked like before the test. Essentially the process is to take some dry ice (while wearing gloves, as it is very, very cold), and simply run the dry ice back and forth over the dent until the metal has c
    1 point
  3. The cooler for a Boxster tip is on the transmission. On a 996 tip it is in the front. Your profile says you have a Boxster S. So you would use a 996 tip cover because you have a third coolant radiator in the front.
    1 point
  • RennTech.org Store at Amazon.com
  • Newsletter
    Want to keep up to date with all our latest news and information?
    Sign Up
