Click here to Donate
Leaderboard
Popular Content
Showing content with the highest reputation on 06/21/2020 in all areas
  1. Tools needed: T20 Torx driver A few flat blades or knifes Soldering Iron Solder Solder wick or desolder tool Parts Needed: http://www.westfloridacomponents.com 1/4W 0.22 ohm Mini-Melf Resistor Beyschlag MMA0204-50AL0R22J - 6 IRFZ24NS FZ24NS HEXFET Power MOSFET International Rectifier - 2 Step 1: Remove Lower panel under drive side. One screw in the middle Step 2: Locate module closest to the center of the vehicle. Module will be installed SIDEWAYS next to the module that has 4 connector ports Step 3: Once module has been removed, use the screwdriver to loosen and eventually
    1 point
  • RennTech.org Store at Amazon.com
  • Newsletter
    Want to keep up to date with all our latest news and information?
    Sign Up
