Click here to Donate
Leaderboard
Popular Content
Showing content with the highest reputation on 06/30/2020 in all areas
  1. 1 point
    Note: Part numbers sometimes change without notice. Always double check with your supplier that you have the latest part numbers. Images are for LHD cars - RHD cars will be on the opposite side. Parts you will need: 1 ea 996 571 219 03 Pollen Filter (Charcoal activated filter) Tools you will need: T25 Torx drive Remove T25 Torx screw that holds the panel cover in place (passenger side front trunk). Remove the panel cover. Remove the particle filter upwards and out of the housing guide. Insert a new particle filter into the housing guide. Check that the filter is correctly fitted and in the correct installation position. Replace the panel cover. Tighten T25 Torx screw that holds the panel cover in place.
  • RennTech.org Store at Amazon.com
  • Newsletter
    Want to keep up to date with all our latest news and information?
    Sign Up
