Click here to Donate
Leaderboard
Popular Content
Showing content with the highest reputation on 01/04/2021 in all areas
  1. Yes, the control is inside the PDK. Likely best it be checked with a PIWIS.
    1 point
  2. P1990 PDK Software monitoring A (or B) of signal processing unit Possible fault causes: - PDK control unit faulty Fault effects: - CAN alive counter freeze - Engine speed limitation - Transmission limphome indication in instrument cluster control unit C150 DME control module, communication Possible fault causes: - No power supply for DME control module - DME control module incorrectly coded - Short circuit or open circuit in the CAN drive - DME control module faulty (in most cases the cause is not the DME control module but incorrect coding!)
    1 point
  3. Sometimes when there is a voltage spike to the system (like connecting a new battery) the programming can get "mixed up". When this happens the best thing to do is have a tech/shop with a PIWIS re-program the affected control module(s). I think it very rare to replace a DME if most everything but one or two items are not working.
    1 point
  4. Hi All, I'm just about to order a 2014 off the dealer lot and it doesn't have any stereo upgrades (no bose, no pcm, no stereo plius, just the 2x25 watts). I currently have a 987 that I'm trading in that did have the Bose. I love music, but this is what they got on the lot. I want to just add a simple self powered kenwood sub under the seat (sw11) or similar this year and then later on upgrade the door speaker and and a decent amp. I want to know if there is ANY way to get a line out from the factor head unit, as I want to keep that stock. I don't want to use a JL Clean Sweep
    1 point
  • RennTech.org Store at Amazon.com
  • Newsletter
    Want to keep up to date with all our latest news and information?
    Sign Up
