  1. IMHO - if nothing is wrong with the clutch then don't spend the money.
  2. If your car is under warranty then the RMS should be replaced under warranty. The clutch would only be replace (under warranty) if it is oil soaked from the RMS leak. Normal wear would not warrant a new clutch under warranty. A clutch replacement with the transmission already out for an RMS would not run you more than one additional hour of labor. Clutch parts will depend on what needs to be replaced - clutch disc, throw-out bearing, and flywheel if damaged. That could be a few hundred to $2000 (flywheels are expensive - $900 plus).
  3. I suggest you find someone with a PST2 (or PIWIS) tester so that you can see what your MAF and TRA/FRA are doing and determine of you have an intake leak or a bad MAF. A PST2 can also test your EVAP purge valve. Fuel vapors are collected in the EVAP canister. As the EVAP canister can only accommodate a certain amount of fuel vapors, the fuel vapors must be taken in and combusted during driving. For this to occur, the EVAP canister purge valve opens. Due to the vacuum predominating in the intake manifold, air is sucked up via the purge air line through the EVAP canister. The air sucked up in this way draws the collected fuel vapors with it. Most of the time when you have a bad EVAP purge valve it also fails the startup test - which gives another fault code also.
  4. From the TSB (which Contributing Members can view): I would say you have the older heat range 5 unless they have been changed.
  5. http://www.renntech.org/forums/index.php?s...ost&p=34937
  6. Chances are there is something on the seal and it needs to be replaced.
  7. They can't be overridden to my knowledge - besides your car would never pass any smog test. P1128 Oxygen Sensing Adaptation, Idle Range, Bank 1 - Below Limit P1130 Oxygen Sensing Adaptation, Idle Range, Bank 2 - Below Limit Since both side of the engine are reporting it -- what that tells me is that you have one more of the following: - an air leak somewhere in the intake system - a bad or dirty MAF - a bad or sticking EVAP purge valve
  8. :welcome: Tire Rack and Custom Alignment (Mountain View) install - under $1000 DIY Brakes - under $300 (as long as rotors are still good) IMHO....
  9. Not on a MY03 or newer... The newer cars use fiber optics connections between the amp and radio/Nav. If you want to go 3rd party on a newer car you have to replace everything and add wiring.
  10. Do you mean 996.110.115.03?
  11. MY01-MY02 Cab amp
  12. Talk to doncapecod...
  13. That is likely because the console removal is covered so well in the B&M Short Shifter Install Instrcutions. You can download them here
  14. 000.044.500.29 Sport Type Running Gear - 10 MM lower (kit) for MY03 Cab, 6spd, 2WD. MSRP - $1274.94 (as of May 2006)
  15. Maybe it was dropped...
  16. I wouldn't worry about the mixture - I would check every couple of days to see if you continues to lower. Also, make sure your (blue) coolant cap part number ends in 01. All of the 00 caps leak.
  17. In order of least costly to most costly... Could be just a re-calibration needed. Could be a bad tank sensor. Could be a bad cluster. Until someone does further diagnosis with a PST2 (or PIWIS) you likely won't know know the cause.
  18. Sounds like a bad fuel level sensor. Any dealer or shop with a PST2 (or PIWIS) tester should be able troubleshoot this down to the faulty component.
  19. Model 996 or 997? you posted in both forums (which is a no-no) Model year? RoW or US? Accelerator pedal? It might help if you tell what you are trying to accomplish.
  20. From what I can tell a P0702 can generate a sub-code (Porsche code only). Here are the sub codes and their meaning: 58 Control module faulty (test internal watchdog) 59 Control module faulty (test external watchdog) 62 Control module faulty (RAM) 63 Control module faulty (ROM) 64 Control module faulty (EEPROM critical for normal function) All of the troubleshooting says to replace the Tip control module except for code 58 which says to re-program the module. That might be worth a try before replacing it.
  21. They are only held on with double-stick tape. You need a hairdryer (for heat), some dental floss (to saw away the glue) and some 3M adhesive remover (to clean the remaining glue off).
  22. Remove the plastic covers from the pivot points and then remove the bolts.
