  1. Interesting that they didn't replace the bellows tube. Those have been a problem on a few older MY99 cars (cracking and leaking). The guess labor is so high because they have to drop the oil pan (drain the oil and refill)... still doesn't seem like more than a couple hours.
  2. Here are all the fan conditions for Carreras:
  3. I suggest you buy the 2002 Technical Introduction CD for $6.23 from My-Porsche.com. It has all of the information you want and more.
  4. Those are the shock tower (spring strut) nuts not the camber adjustment bolts -- 63 ft/lbs
  5. Do you mean Zaino? Zaino
  6. I don't know that it would hurt anything in normal driving. Up hills or down hills might spill out?? I don't know?
  7. 11.3:1 Light alloy, pressed. Forged. Yes, forged. Sorry, not specified in the manual The camshafts use Variocam so you might consider the camshafts from the X51 kit. As a matter of fact if I were TCing or SCing a Carrera engine I would start with the X51 engine upgrade kit. What year is the car? (i.e. 3.4 liter or 3.6 liter)
  8. Yes, 999 113 490 40 is rear main seal. Better yet it is the newest and best design.
  9. IMHO... both add some intake noise but have never been proven to add much if any HP. Nor because they don't but because no one has done good before and after dyno runs. With that said, I use the BMC and am very happy with it. I did some of the Fabspeed mods on my own (like removing the two screens) and I am have with that also. YMMV
  10. It bleeds air out of the system without letting the coolant out. Cup cars actaully run with this open all the time.
  11. Updated August 15, 2003 Here is a list of the most popular Porsche shop and technical publications: Model -- Title -- supplements -- volumes -- part number -- approx. price Boxster / Boxster S -- Workshop Manual -- 63 supplements -- 15 volumes -- WKD-483-521 -- $451.41 Carrera (1999 on) -- Workshop Manual -- 79 supplements -- 15 volumes -- WKD-483-721 -- $478.77 996 Turbo / GT-2 (2001 on) -- Workshop Manual -- 32 supplements -- 13 volumes -- WKD-484-021 -- $564.27 Cayenne -- Workshop Manual -- 13 supplements -- 16 volumes -- WKD-484-221 -- $1500.00 These prices and one source are from My-Porsche.com
  12. From the Tech Information Book
  13. Yes, bleeding the brakes (and clutch) is one step in my DIY page. DIY pages
  14. I think it is a DIY as long as you have tools. I sent you an email...
  15. LOL Don... like minds :lol:
  16. As sentipede there are no differences except for color. If you are changing the calipers out this would be a good time to replace pads, vibrations dampers etc. since the procedure is pretty much the same. Here is a link to my Brake Pad DIY
  17. What model year is your car? They are slightly different with MY02 on.
  18. The longer bracket (that pushes the radiator away from the chassis) should be on the bottom. Perhaps you can see it in this image.
  19. Porsche recommends that whenever a spring type clamp is removed (anywhere on the car) to replace it with the screw type hose clamp. If it is not leaking then you are likely okay (for now). If you do develop leaks then you will want to use the screw type hose clamps to fix the leak.
  20. Just the OBDII port (PST2). They will transfer your mileage, settings (US miles, temperature, etc.), and VIN. PST2 will then transfer the information into the new cluster (after it's in your car) and the dealer will record it in PCNA's database.
  21. If you want your own OBDII test hardware/software prices start at $125 and go to $10,000. I happen to own the $125 software and cable solution that runs on my laptop. It all the standard OBDII diagnostics and has access to some of the Porsche specific diagnostics. You can find more info here. I get my P code list along with a troublshooting tree from AllDataDIY.com. About $24.95/first year for the first car and $14.95 for additional cars and renewals. If you are looking for a good shop in your area... I am not sure exactly where you are located but Steve Weiner at RennSport Systems in Portland has a very good reputation. His contact info is: 503-244-0990 or porsche@rennsportsystems.com
  22. There are two per catalytic convertor. One before and one after each cat -- for a total of four per car. Many times other faults (i.e. MAF, loose gas cap, bad bellows tube, etc.) can trigger a bad reading at the oxygen sensor. The oxygen sensor reading bad is perhaps a result of some other problem up stream. If there is a "P" code fault then all the possible causes of that P code should be explored (IMHO). Sometimes they go bad -- but sometimes it is because they got oil or water on them and they get damaged easily.
  23. My pleasure! Glad it worked out :thumbup:
