  1. Try 2812
  2. From the Guidelines/Rules here: "Copyrighted material: By registering here you agree not to post (or link to) any copyrighted material unless the copyright is owned by you or by this site. Repeat offenders will be banned from this site and their accounts, as well as the offending material, will be deleted." This topic is closed.
  3. Those springs a replacement for the original M030 springs in 2009. So, if you documents are not newer than 2009 they could be incorrect.
  4. Are you sure the upper mark is yellow and not an aged white?
  5. The inner temperature sensor is located on the right in the plenum panel (at the air inlet housing for air conditioning). 1. Unscrew fastening screws 1 and remove air inlet housing cover 2. 2. Turn inner temperature sensor clockwise arrow and remove it to the rear. 3. Disconnect connector 1 from the inner temperature sensor 2. Installation is performed in reverse order.
  6. 99655221103 = "not a valid part number".
  7. That part number is for as MY2003 and newer. I don't know if it will work since there were many changes including the mail ail vent and the instrument cluster.
  8. Try 9257
  9. Try 9416
  10. You are likely looking at fuel or brake lines.
  11. Try 9020
  12. They are micro-encapsulated (self sealing) bolts - 7.5 ftlb. (10 Nm).
  13. Try 2871
  14. Try 9872
  15. Try 4864
  16. Try 4693
  17. Try 2726
  18. Hmm... Not sure Durametric is right... 997.641.981.35 is the part number for your instrument cluster - which can not cause a CEL or high idle. Perhaps make sure you have the latest software and try again.
  19. Magic
  20. If this is a manual transmission car - have you checked the clutch switch? I had a similar issue and it was an intermittent clutch switch.
  21. Try 9042
  22. Perhaps a salvage yard - just make sure it has the same part number as there were several changes over the years.
  23. Yes, on 2004 and older PIWIS actually uses the PST2 software for it's work.
  24. Try 9808
