  1. If you do not feel comfortable doing this procedure please take your car to a shop that has experience doing this. This is straight from the factory manual. Bleeding the spoiler pump unit 1. Pulling out pump Pull hydraulic cylinder 2 out to the dimension Y = 35 +2 mm . To do this, connect 12 V to the pump. Observe polarisation arrangement A. 2. Bleeding short hydraulic line Slowly tighten short hydraulic line 4 until the hydraulic cylinder 2 moves. If the hydraulic cylinder has reached the lower mechanical stop inset X, push back onto the stop if necessary, hydraulic lines must be laid parallel to each other inset Z. Tighten banjo bolt 3. Tightening torque: 15 Nm (11 ftlb.) 3. Bleeding long hydraulic line Slowly tighten long hydraulic line 5 until the hydraulic cylinder 2 moves. If the hydraulic cylinder has reached the lower mechanical stop inset X, push back onto the stop if necessary, hydraulic lines inset Z must be laid parallel to each other. Tighten banjo bolt 3. Tightening torque: 15 Nm (11 ftlb.) Note: Use only Pentosin CHF 11 S (or it's replacement).
  2. That is a little high. I would make sure both fans are running. Sometimes a ballast will go out and only one fan works then.
  3. Yes, Have a look at Robin Sun's mod for the 993 here
  4. How to Replace the Ignition Switch
  5. Hey I don't make those decisions Porsche does... All the aluminum/leather stuff is hand made as etc., etc.
  6. From your model year order guides it would be any option starting with "X".
  7. Perhaps this will help... 1. Recirculating air valves 2. T−piece 3. Recirculating air valve hose 4. Air hose 5. Recirculating air valve hose 6. Pipe 5 x 1 x 250 7. Curved hose 8. Pipe 5 x 1 x 245 9. Four−way branch piece 10. Pipe 5 x 1 x 250 11. Three−way branch piece 12. Pipe 4 x 1 13. Distributor pipe 14. Vacuum accumulator 15. Combination valve for secondary air 16. Fuel pressure regulator 17. Electric switch−over valve for secondary air 18. Pipe 4 x 1 x 350 19. Pipe 4 x 1 x 500 20. Pipe 4 x 1 x 500 21. Curved protective hose 22. Check valve
  8. Consider the RoW Sport Suspension (M030). That kit will lower 20 mm in the front and 10 mm in the rear. Kits can be had for around $1000 but you will need to install it and get an alignment also.
  9. 236 - 18" tires 09991 - means that one or more options on your car are part of the Porsche Exclusive Option program. That means that the parts specially (usually hand made) for your car. Replacement of many Exclusive options takes more time as the parts usually have to be re-made. In some cases Porsche requires a VIN number before building exclusive replacement parts.
  10. Yes they are in and behind the front bumper. For a DIY see my 3rd radiator install - the part about removing the front bumper and cleaning the radiators -- here.
  11. Great job! I moved this to the permanent Cayenne DIY - Accessories section.
  12. You put the code in when it prompts (as I recall). The code goes in as stars (*). Also, try 4520 or 4418. My little program doesn't work on all the older radios...
  13. X76 - Flared rocker panels or Inner door sill guard (it is listed both ways) 226 - are you sure it isn't 236 - 18" tires 762 - sorry?
  14. The Wurth Silver wheel paint followed by the Wurth Clear coat has worked well for most.
  15. You do not have to remove the dash to replace those pieces. The defroster pieces are know to break the plastic clips when they are replaced. I think the sun causes the plastic to become brittle there. It is best to buy a few spares before doing the replacement.
  16. I think your first thought is likely correct -- sounds like a wheel bearing.
  17. That is a good idea. :D A small problem is that recently Duarametric put a three car limit on the their standard software (Enthusiast Package). Their "Professional Kit" version is still unlimited. So only folks with the Professional version should offer to run the Durametric Software on other's cars. I have a PST2, PIWIS, Durametric Software, and Car Code OBD-2 software. I now have access to PIWIS 2 also. I am in Roseville California (near Sacramento). We will likely start a "Work on Cars Day" in our area soon - similar to what Jeff (Tool Pants) and I did in the San Francisco Bay area. I moved this thread to the Diagnostics, Tips and Tools Forum and pinned it at the top. Please feel free to add to this thread of have have one of these tools and are willing to help your fellow Porsche enthusiasts!
  18. No, not at an oil change but a transmission oil change. Porsche says 90,000 miles in their recommended maintenance. You can find more Maintenance Schedules info here.
  19. A Porsche "Workshop Campaign" is not a recall. It is a Porsche (voluntary) campaign to fix a number of minor issues in a number of cars. Sometime these are VIN specific and sometimes they are not. These are voluntary on your part also. You do not have to go in and have these items fixed/upgraded to current production levels... although I do not know why you wouldn't. These are general tasks that should be performed on any car (as specified in the bulletin) at the next opportune service. In the TSB section you will see a number of bulletins with the number beginning with "W" - these are all Workshop Campaigns. For example the 996 had 8 workshop campaign bulletins and the Cayenne had 19.
  20. Porsche had a retrofit kit for the 986 and 996 complete with instructions - I have not see a kit like that for the 987 or 997 yet. I am not saying it can't be done but you would likely need to get each individual part.
  21. Do you have a pic? Also, we will need the color.
