37,276 -
Days Won
528
Posts posted by Loren
Normal idle speed on a 3.4 liter car is 700 RPM.
I don't think idle is your problem - the CEL and smoke is.
P1128 Oxygen Sensing Adaptation Area 2 (Cylinders 1 . 3) - Rich Threshold
P1130 Oxygen Sensing Adaptation Area 2 (Cylinders 4 - 6) - Rich Threshold
These mean that the fuel/air mixture is so lean that sensing has reached its rich threshold. That is, you have an air leak that the DME can not add enough gas to meet proper mixture (and emissions).
Probable causes are (from the OBD II manual):
- Intake air system leaking.
- Fuel pressure too low.
- Volume supply of fuel pump too low.
- Fuel injectors fouled.
Since you had (or still have smoke) then the oil separator is a potential air(/oil) leak. Even a bad oil filler cap or hose can cause this too. You need to find the source of the air leak.
I just sent it to you via email...
Yeah, those that are listed in the Cayenne Quality-improvement Workshop Campaign were only sent to dealers. If I can get a hold them I will post them. They will all have a VIN list with them since not all Cayenne's were affected.Loren - thanks for the help. I did have one additional question - I do not see the W500 series in TSB section. Am I looking in the wrong place?Thanks again for the help.
K
If your air bag light is on then the only way to turn it off is with a PST2 or PIWIS tester - at an OPC or shop. If you take it to an OPC then they can check your PCM1 serial number against the code you are entering and get you the right one if it is not correct.
They should both work fine - the boot usually stays with the shift lever.
In the past they sent them out about once a month in a batch mailing. In late January Porsche changed the way they are distributing TSBs - no more paper mailed to subscribers. We are looking into what our options are at this point.
The TSBs are all grouped by number. Porsche uses the same sequence for sports cars and suvs. The number sequence follows the factory service manual sections to make it easier for the technicians. For instance Group 1: Engine would have TSBs starting with "1xxx" and Group 4: Running Gear would have TSBs starting with "4xxx". Here is the general sequence:
Group 0: Entire Vehicle
Group 0: Diagnois, Part 1
Group 0: Diagnois, Part 2
Group 1: Engine
Group 2: Fuel, Exhaust, Engine Electronics
Group 3: Transmission
Group 5: Body
Group 6: Body Exterior
Group 7: Body Interior
Group 8: Air Conditioning
Group 9: Electrics
Some items are covered under "Campaign Information". These are also included with the TSBs and are labeled with "W" numbers. "W" is for Workshop Service Action. Porsche started a Cayenne Quality-improvement Workshop Campaign in the Fall/Winter of 2004. For a complete listing go to the Contributing Members forum and read the Cayenne item "Cayenne Quality-improvement Workshop Campaign, Fall/Winter 2004" pinned at the top of the forum.
Your dealer should check your VIN against all of these outstanding WSA's and perform any that are needed - at no charge. Some of the items you describe are simple software updates to the PCM2 and DME.
The top clips are on the vent. The parts list only shows the whole vent assembly.
Have a look at Scouser's In-dash Spoiler Switch Mod in the DIY section here. He describes how he got power for illumination.
There should be locking tabs on the back of the U shaped part that lock into clips in the vent and the sides.
With or without headlight washers?
996 613 508 10 A05 Cap with symbol (no headlight washers) -- retail $3.47
996 613 507 10 A05 Cap with symbol (with headlight washers) -- retail $3.47
That part number does not come up in the parts system. The early Boxster side skirts were 986 559 983 00 and 986 559 984 00 (left and right sides).
Carrera side skirts all start with 996 559 983 xx and 996 559 984 xx.
That may be the raw (pre coated) part number for a Boxster side skirt. Unless that is the basis for the RUF side skirt (they build on to that) it will not likely fit a Carrera.
It was $7 when I bought one in 2000. I think Sunset Imports (Porsche Parts at Dealer Cost) has them for around $20.
Such a shame that Porsche has decided to gouge folks for this simple item.
Have them check the swaybar to see if it is loose (fairly common). They should check the strut too - fairly rare but I have seen a couple loose or bad struts.
IMHO - no. That weakness from earlier 911 designs was fixed starting with the 986 and 996 series cars.
Remove your battery cover and you will see that you already have two strut braces. As a matter of fact these are the same strut braces used in Cup Cars.
You've got mail...
You can find Scouser's DIY here.Have a look at my 996 in-dash tail switch instructions in the DIY section. Specifically instruction #11. There are pictures showing you step by step instructions. -
Most of the signals come off the DME (engine computer). Unless your VW type 1 is "really new" I doubt it has those level of signals.
Scouser,
Any pics? Like before and after? (during if you have them too)
The glass alone (996 542 512 02) retails for $132.36. I would expect at least a couple hours labor to install, align and test.
Depending on your insurance deductible your comprehensive insurance should cover this.
I have added the preliminary MY06 Order Guides for the Cayenne (V6), Cayenne S and Cayenne Turbo. Other models will be added as they become available.
I have am "always open" PSE. I live in Morgan Hill.
Sorry no, when PET says "Qty Model" "8" - that means 8 used on the car.
cd holder removal
Push the buttons to release all the CD trays. Grab them all and pull.
That's it!
