37,276 -
Days Won
528
Posts posted by Loren
MY99 was the first US year for the 996 . It should not be a problem if it has had the service bulletin fixes. Any Porsche dealer can check (for free) using the cars VIN. Also, look on the door for the build date (not delivery - build). Late MY99 cars had most of the minor problems fixed at the factory. So, if your car is May or June 1999 then many service bulletin fixes have likely been done. I own a June build MY99 and I have had very few problems...
RMS is dead center where the engine joins to the transmission. If it's blown oil all over the engine then it is pretty bad and you will likely need a new clutch too.
If you have access to a computer that can trigger the ABS valves then you will get a slightly better bleed job (IMHO). Normally the ABS valves only open when they need to. So, even a pressure bleeder will not get all the old fluid out - not a big deal though as we are only talking a few cc.
Just got the PCM 2 Install Instructions TSB from Porsche. It is in the TSB viewing section for contributing members.
Items 8 and 9 are antennas for the Entry & Drive.
Hi, Loren. Is that from a U.S. dealer or Carnewel? I'd rather try to buy one from a closer vender. A large piece of metal can only cost a hundred bucks or so and then cost several hundred dollars in freight from a foriegn country. I ship stuff to Hawaii all the time from Japan, P.I., Indonesia and other S.P. spots and you wouldn't believe the freight, customs, etc...
My quote above is retail from a US dealer. With a PCA discount or from the Porsche Parts at Dealer Cost link above you can likely get it cheaper.
Really??? They did mine without removing my bumper....it was tight but they did it :D
Front openings on a TT bumper are MUCH larger than a Carrera or GT3 bumper. Definitely can't be done on a Boxster or Carrera without removing the bumper -- except by skilled micro-surgeon - and they charge too much :lol:
996 107 981 00 Protective Plate
Price as of Nov 2003 was $110 (retail)
Yup, front bumper needs to come off to change the horn(s) - about a 30 minute job. Just to the left of the center radiator in this pic.
I would get jack stand with flat tops or buy the one that have pins for jack points. Occasionally, they are sold on e-Bay. Or perhaps some one else here knows where to buy them.
The wire is the radio antenna and box with the white label is the radio antenna booster (one of two).
If you have the Entry & Drive option there is a TSB for some updates for problems. On the D&E option the door handles have some of the triggering problems.
Yes, center console in "sportsilver" for MY03 or newer.
George,
Thanks - I have a lot folks (and manuals) around me with lots of help.
P0102 is consistent with an open circuit or short to ground with the signal from the mass air flow sensor (MAF).
5525 is a Porsche only code that says it is getting inconsistent readings from the DME as to engine load.
msindi is likely right that it is something your tuner has done in the chipping. A simple test would be to revert back to a standard DME and see if the faults stay gone.
Yes, most dealers get a weekly print-out so they don't have to request a new one search for each one.
I mean this one here
955 044 000 29 Roof Strips (1 set).
Be sure and get the separate instructions.
It's here if you do a search ;)
thanks Loren, you are the most helpful person.
I do not think it comes with the strips on the roof of the cayenne. May I also know the part number for the strips? I will ask for the instruction.
I did ask you about the front bumper part number few weeks ago and I bought it already and painted and it replaced the old one :)
thanks!!
Do you mean the Roof Rail Cross Members?
955 044 000 30 Roof rail, complete set
Make sure they give you a copy of the install instructions if you are doing this yourself.
Try the folks at Sunet Imports - Porsche Parts at Dealer Cost link at the top of page...Where do I purchase the PSE Exhaust? The Dealer? I called them yesterday and the parts person still did not call me back.Thanks
Just updated... now version 0.4
GT2 problems fixed ;)
Try doing a search as both have been done and comments are here. As well their are pedal examples in the Garage...
Yes... but you will need a scan tool/software. There are several discussed here. Do a search for scan tool.
Check out our new decal and racing numbers store (provided by Xenonmods.com).
Details are here and the store is at the (red) link above Decals/Racing Numbers
Number 14 is: 996 504 561 00 Cover
About $43 according to my Nov 2003 price list
Remote's antenna
in 9PA, 9PA1 (Cayenne, Cayenne S, Cayenne Turbo, Cayenne Turbo S)
There are 3 item 8 antennas and 2 item 9 antennas for Drive & Entry systems per car (according to the parts list). Item 1 is the standard alarm/drive block. I would look at the wires coming out to find an antenna or to see if it uses the radio antenna. There is not a separate antenna listed in the parts list (that I can find).
