37,277 -
Days Won
528
Posts posted by Loren
Covers all Carrera (996), GT3, TT / GT2 and Boxster (986) cars
Here is the long explanation from the service manual on the flashing coolant light.
"Four functions of the coolant warning light:
1. Engine coolant level too low -- light flashes slowly (0.5 Hz)
2. Engine compartment temperature too high -- light flashes slowly (0.5 Hz) (engine compartment blower might be faulty)
3. Engine coolant temperature too high -- light is lit; pointer on the right
4. Temperature sensor at water outlet faulty -- light flashes rapidly (1 Hz) ; pointer on the right
Note: The temperature warning in point three is indicated if the conditions "engine coolant temperature too high" and "engine coolant level too low" are present simultaneously."
2 hours ago, ForTheHalibut said:
CDR-220
2000 Boxster
Type 4462
Serial X5026275
Thank you!!!
Try 8732
- 1
16 hours ago, andrewm_renntech said:
I'd love a copy, @Loren. Thank you.
I've read elsewhere you will in fact need a rivet gun to install the blind rivet nuts. And that there are several templates you need to install the front and rear holders to align them to the body. Is that the case? The factory repair manual simply states, "ensure that they are fitted correctly and not damaged; if necessary, replace."
Just purchased the the brackets, screws and running boards from the junkyard. Forgot to see how the rivet nuts were fitted. I believe this is the correct part number I need: Blind rivet nuts 904-085-04
Copyrighted material:
By registering here you agree not to post (or link to) any copyrighted material unless the copyright is owned by you or by this site. Repeat offenders will be banned from this site and their accounts, as well as the offending material, will be deleted.Several years ago Porsche's lawyers sent me a "take-down notice" to remove all copyrighted Porsche material from the website or face litigation. I had no choice but to comply with their demands.
3 hours ago, Speedmob said:
CDR220 in Boxster S '01
Type 4462, Serial X5022158
I am stuck on WAIT and no code - thanks in advance!
From the Lost Radio Code FAQ...
"I get a WAIT on the display - what do I do?
You have to wait at least 30 minutes before trying again."Try this code 5468
3 hours ago, wldrose27 said:
I have a 1999 Boxster, my radio is a CDR-220 serial number W5009357 -
I cannot unlock the radio, it says WAIT....
Thank you.
Try 9432
50 minutes ago, Neil Chirico said:
I had an aftermarket radio installed when I bought my 2001 986 but prefer to have the original CDR-220 factory-installed radio so I found a used one. The model is CDR-220 and the serial number is 25015991. Let me know if you can get me the code. I'd like to install it into my Boxster. Much thanks!
Try 1309
Don't forget to hook up the wire (to the radio chassis) for the alarm system.
- 1
There is a special bleeding procedure in PIWIS (not sure about Durametric) that bleeds the ABS pump by running the pump and opening and closing the valves.
Yes. If you are getting a dash light then the car needs to be checked for suspension faults using a Porsche specific diagnostic tool like PIWIS or Durametric.
11 hours ago, Qatar Taro said:
I tried to enter Jack mode as per manual, hold the switch forward 10 seconds in Normal position but It couldn't enter to jack Mode. No sigh came up to Main display. What shall I do ? My car is 2008 Porsche 957....15years old.
Does the air suspension operate normally now - to raise and lower on demand?
If not then use a Porsche specific diagnostic tool (i.e. PIWIS or Durametric) to check for fault codes.
- 1
434 Work instructions for cars overseas (924 and 944)
Not a 996 option code to my knowledge.
9 hours ago, Tesla said:
Hey I have a 2002 boxster with a CDR-220
my serial number is 15006341
hopefully that’s the right serial because my screen is damaged a bit. Thanks in advance!
Try 2845
The standard radio does not have an external amp = the BOSE does.
You have posted the same thing four times now. Please wait for someone to reply to your first post. Also, please re-read the site Guidelines that you agreed to when you registered here.
"Please post your messages in one forum only. Crossposting, double posting, triple posting, etc. are all a waste of time and valuable resources. If you post the same message in multiple times or in multiple forums, we will delete the ones we feel are inappropriate."
9 hours ago, jojtekbarszczyk said:
Hello,
My battery didn't survive the winter intact and so I'm left with a radio needing the code
CDR21
S/N: W5017030
Thank you very much in advance
Try 1431
3 hours ago, richbay said:
I too am looking for a code for my cdr22
BE6621
serial 25009953
Try 3580
A DME 7.2 and DME 7.8 are not interchangeable.
The 7.8 goes with a number of engine changes such ar Variocam, returnless fuel supply, etc.
6 hours ago, Mikco said:
Hi!
If anyone could help. I would need wiring diagrams for 2000 and 2001 and 2002 Carrera 2. Please! Especially DME 7.2 and 7.8 wiring is in needed but also IMMObilizer for these years is in need.
I'd really appreciate if anyone could help me!
Those are copyrighted Porsche materials - we can not and will not distribute those here.
5 hours ago, dyabecker said:
Hello all of everyone else who has made it here after being locked out of your stereos and also hello to those who will end up in the same position in the future!
I have of course been locked out of my cdr-220 and was wondering you could also help me to get that pesky 4 digit code as well?
I have a 01 boxster
Vin- wp0cb29821u661289
Cdr-220
Model- be 4462
Serial- y5048541
Thank you for all the help youve been over the years!
Try 1738
2 hours ago, Daniel Torefeldt said:
Hi,
could someone help me with the code to my CDR-22.
4467
15038473Try 7609
2 hours ago, CP996 said:
Hello,
Need a radio code for:
2000 Porsche 996 Carrera 4
Cr-220
Type 4362
W50022H2
Thank you so much 🙏
I need the radio serial number (numbers).
See the Lost Radio Code FAQ
1 hour ago, GrantatRenu said:
Trying to help out a customer on their car:
Becker CR-220
Becker 1
Serial: Y5040634
24/99
EDIT: Dealer contact reached out to us with it. Thank you though Loren for this help that you provide the Porsche community. You're a hero in my book.
Try 4561
40 minutes ago, richardleon033 said:
CR-220
BE6624
25005781
2002 Porsche Boxter S
please and thank you 🙏
Try 9875
- 1
2 hours ago, David Alba said:
Requesting code, 1999 C2.
Becker cdr 220
BE 4462
W5002907
Try 0703
Sounds like you have one or more locking zones (doors, gas door, rear hatch, etc.) that are not latching.
You will likely need a PIWIS tester or Durametric to find the fault code(s) to easily determine the problem.
Coolant temperature warning light flashing, temperature pegged on low end of scale
in 986 Series (Boxster, Boxster S)
