37,277 -
Days Won
528
Posts posted by Loren
The exact model and year of your car is always helpful;.
7 hours ago, STS said:
Loren,
Sorry for the redundancy with a second post but I just found this topic thread for requesting help with radio codes after I sent a separate message to you earlier. Below is the information in my original post.
Thank you in advance for any help you can provide.Hello,
I just replaced the battery in my 2001 996 cabriolet and I do not have the stereo code. Would you be able to help please?
CDR-220
Type: 4462
Serial #: Y5053833
Thank you!
Try 2752
- 1
44 minutes ago, CJChaps said:
Hi Loren. So, my radio says "wait". I disconnected the battery. Once for 2 hrs, then again for overnight. I even pulled it out and unplugged it... Any tips? Also, if I swap the radio for aftermarket while the stock one says wait, will it cause issues? E. G. Is the radio locked or does the lock come from the ECM?
Thanks for your help.
Clint
Somebody didn't read the Lost Radio Code FAQ...
"I get a WAIT on the display - what do I do?
You have to wait at least 30 minutes before trying again." -
1 hour ago, El Duderino said:
Hello, need help please.
- 2011 996 base Cabriolet
- Type 4362
- SN 15050333
Thank you so much!
Try 0586
- 1
From what I can see in the photo it appears to be the oiled filter.
3 hours ago, Red 5 said:
Hi,
would really appreciate some help with getting the radio code.
i have a Becker CDR 21
model number BE 2280
serial number V5012467
thank you
Try 4862
12 minutes ago, theblackshadow06 said:
How did u fix u problem ?
A double beep means that there is an alarm fault that can not be reset. You need to read the fault codes for the alarm system to location the problem sensor or control box.
4 hours ago, transam1245 said:
Hello,
my battery went dead and of course I have no radio code.
Can anyone please help?
Thank you, Douglas
Becker CDR 220
S.N.#15006587
Try 6576
57 minutes ago, Bartek said:
Hi, can I get your help with radio code?
Type CDR220
model no BE6625
Serial no 15000638
Try 4593
6 hours ago, adamn185 said:
Hi, I can’t find my radio code. Can you help?
CDR-220
Type 4462
Serial Number W5006434
Try 7173
1 hour ago, Tim L said:
I need help with my radio code. Could someone help?
BE0780
Serial Number X 9010538
You did not read the Lost Radio Code FAQ
"Which radios fitted to Porsche can have their unlock code recovered through serial number?
- CR-220/CDR-220 - Becker
- CR-210/CDR-210 - Becker
- Traffic Pro NAV/CD - Becker" -
Before the 17 digit VIN numbers there was little information that could be gleaned from the VIN. Sorry.
27 minutes ago, surfndream said:
Trying to find radio code:
1999 986 base
Becker CDR 220
Serial # X5024200
Thank you very much!
Try 4928
Have you used a Porsche specific scanner to get fault codes?
If so, please list them here.
7 hours ago, alxwhy said:
Hi - need help with the radio code:
cdr-220
model 4462
serial: Y5046246
thanks! And Merry Christmas!
Try 4916
47 minutes ago, Munkustrap said:
New 996…. Lost code! Loren, I beseech thee please!
BECKER CR-220
MODEL. 4362
SERIAL W 5005005
Thank you!
Try 5195
32 minutes ago, Jerry Salmons said:
Hi, I have lost my Radio code for my 2001 Porsche 911TT. Getting a WAIT response after installing a new battery in the car. The serial # on the radio display is X5036208 Any help would be greatly appreciated.
Thank you, Jerry S.
Try 4612
3 hours ago, mktowey said:
Cdr-220
Type 4462
49/98
X5017388
Try 3031
You might want to check that your Durametric is up to date with revisions. Also, it could be a bug in the software - but the only way to tell might be using a PIWIS tester.
- 1
36 minutes ago, Clifton Townsend said:
Trying to get my pcm code for my 2000 carrera 911
From the Lost Radio Code FAQ...
"Can you give me a code for my PCM?
These units are manufactured jointly by Siemens and Becker, and the only place where you can get the codes required is from the dealer/OPC. The PCM’s require two codes, the ICS/Siemens code, and a Becker code. The ICS is the first code requested.
Sorry, the only place you can get a PCM code is from a dealer/OPC." -
Many times control unit issues can be fixed by re- programming that module. If that does not work then a new control unit will need to be installed and programmed to your car.
Cluster compatibility -996, c4, manual
What year is your car?
