37,291 -
Days Won
530
Posts posted by Loren
57 minutes ago, Bartek said:
Hi, can I get your help with radio code?
Type CDR220
model no BE6625
Serial no 15000638
Try 4593
6 hours ago, adamn185 said:
Hi, I can’t find my radio code. Can you help?
CDR-220
Type 4462
Serial Number W5006434
Try 7173
1 hour ago, Tim L said:
I need help with my radio code. Could someone help?
BE0780
Serial Number X 9010538
You did not read the Lost Radio Code FAQ
"Which radios fitted to Porsche can have their unlock code recovered through serial number?
- CR-220/CDR-220 - Becker
- CR-210/CDR-210 - Becker
- Traffic Pro NAV/CD - Becker" -
Before the 17 digit VIN numbers there was little information that could be gleaned from the VIN. Sorry.
27 minutes ago, surfndream said:
Trying to find radio code:
1999 986 base
Becker CDR 220
Serial # X5024200
Thank you very much!
Try 4928
Have you used a Porsche specific scanner to get fault codes?
If so, please list them here.
7 hours ago, alxwhy said:
Hi - need help with the radio code:
cdr-220
model 4462
serial: Y5046246
thanks! And Merry Christmas!
Try 4916
47 minutes ago, Munkustrap said:
New 996…. Lost code! Loren, I beseech thee please!
BECKER CR-220
MODEL. 4362
SERIAL W 5005005
Thank you!
Try 5195
32 minutes ago, Jerry Salmons said:
Hi, I have lost my Radio code for my 2001 Porsche 911TT. Getting a WAIT response after installing a new battery in the car. The serial # on the radio display is X5036208 Any help would be greatly appreciated.
Thank you, Jerry S.
Try 4612
3 hours ago, mktowey said:
Cdr-220
Type 4462
49/98
X5017388
Try 3031
You might want to check that your Durametric is up to date with revisions. Also, it could be a bug in the software - but the only way to tell might be using a PIWIS tester.
- 1
36 minutes ago, Clifton Townsend said:
Trying to get my pcm code for my 2000 carrera 911
From the Lost Radio Code FAQ...
"Can you give me a code for my PCM?
These units are manufactured jointly by Siemens and Becker, and the only place where you can get the codes required is from the dealer/OPC. The PCM’s require two codes, the ICS/Siemens code, and a Becker code. The ICS is the first code requested.
Sorry, the only place you can get a PCM code is from a dealer/OPC." -
Many times control unit issues can be fixed by re- programming that module. If that does not work then a new control unit will need to be installed and programmed to your car.
8 minutes ago, Bertrand77 said:
Hi, can’t find my code anymore :
Becker1
Type : 4467
Series : 15037430
Thank you
Try 6951
2 hours ago, Edcantera said:
Hi guys,
looking for the code for a 2001 996 base Carrera.
these are the details:CDR-220
ser: 15087199
24/99
type 4462
thank you for your help!
ed
Try 0876
- 1
9 hours ago, Brendan Dolan said:
Hello! New guy here. Got a 986 for my Dad, and after a battery replacement the radio code isn't working. CDR 220 model 4462, serial number x5028266. Appreciate the help!
Try 5210
46 minutes ago, stcan said:
Thanks for your help Loren, it's the control unit. I replaced it and problem is fixed.
Pretty much the brake switch and control unit.
Assuming there are no shorts to ground it is likely the issue is in the control unit. Many times control unit issues can be fixed by re- programming that module. If that does not work then a new control unit will need to be installed and programmed to your car.
The first thing I think is to make sure it is the stop light or tail light or fog light.
I would make sure it's not the fog light, also a bad headlight switch could also cause the issue.
1 hour ago, Milester986 said:
I have just bought a 2000 Boxster from my sister. We did repairs with battery disconnected. Now can't find radio code to operate radio. Have read LOST RADIO CODE First doc and retrieved serial #. Any help would be so appreciated, thank you.
Radio: CDR-220
Serial: Y5042538
Try 9014
1 hour ago, jimo55 said:
Hello -
I have a 2001 996tt with Becker CDR-220.
Had work don over the last few weeks and lost the radio set-up.
Serial number: 15089443
Any help recovering the code would be appreciated.
Thank youTry 3595
1 hour ago, Will Corder said:
Need radio code for
1999 Porsche Boxster
Type 4462
CD. CDP2081
48/98
Ser. X5025620
Please help me with the radio code
Will
Try 9604
Lost Radio Code - post your request here
in Lost Radio Codes
Try 6576
