  1. From the Lost Radio Code FAQ.... "Can you give me a code for my PCM? These units are manufactured jointly by Siemens and Becker, and the only place where you can get the codes required is from the dealer/OPC. The PCM’s require two codes, the ICS/Siemens code, and a Becker code. The ICS is the first code requested. Sorry, the only place you can get a PCM code is from a dealer/OPC."
  2. Yes, the required emergency release inside the trunk (red handle).
  3. From the Lost Radio Code FAQ ... "Which radios fitted to Porsche can have their unlock code recovered through serial number? - CR-220/CDR-220 - Becker - CR-210/CDR-210 - Becker - Traffic Pro NAV/CD - Becker"
  4. Not sure how it is configured. If the resistance changes with the switch then the switch is likely okay.
  5. You can use an ohm meter to see that the switches are working.
  6. From the Lost Radio Code FAQ ... "The suggested number did not work - what do I do now? Most often when the code we give you does not work it is because the serial number came from an old card in the car rather than from the procedure stated above - or a typo in the serial number submitted. Double check the serial number you submitted using the procedure above again. If that does not work then you will need to contact a dealer or Becker. Becker charges to look up your code and some dealers also charge. Our program works maybe 99.9% of the time but we have no explanation why it doesn't always work."
  7. From the Lost Radio Code FAQ ... "I get a WAIT on the display - what do I do? You have to wait at least 30 minutes before trying again."
