  1. Exact model and year of your car please - and what specific part(s) are you interested in?
  2. You are likely going to need a shop with a Porsche PIWIS diagnostic tool.
  3. Try re-training the windows. Hold the button down until the window goes down all the way - then do the same for the up motion. If that does not work then there is likely a bad window regulator or other window/door issue.
  4. From the Lost Radio Code FAQ... "The suggested number did not work - what do I do now? Most often when the code we give you does not work it is because the serial number came from an old card in the car rather than from the procedure stated above - or a typo in the serial number submitted. Double check the serial number you submitted using the procedure above again. If that does not work then you will need to contact a dealer or Becker. Becker charges to look up your code and some dealers also charge. Our program works maybe 99.9% of the time but we have no explanation why it doesn't always work."
  5. From the Lost Radio Code FAQ... "I get a WAIT on the display - what do I do? You have to wait at least 30 minutes before trying again."
  6. Yes, there was likely an 04 version as well as 05. Any version 03 to 05 should work on a 3.6 liter car.
  7. if you are buying a kit - 000 044 200 19 Left Muffler - 996 111 984 03 Right Muffler - 996 111 985 03
  8. If your car is a 3.4 liter then it does not matter. They both sound the same and nobody sees the tubes.
  9. The small tube versions were likely out of stock 10 years ago.
