Pkcayenne
Everything posted by Pkcayenne
  1. Hi all my next challenge is my 04CTT, the below isn’t working turn signal stalk lights stalk horn tiptronic volume for radio selecting any menus on the dash electric adjustment for steering wheel any ideas relay of something else appreciated,
  2. Hi all I’ve been fighting with the cayenne again let’s me put the key in and turn it then I get steering fault as attached any ideas of a way around this or a reset thanks car won’t start
  3. Hi more like 8 I drilled them out and replaced with screws did all the work twice with the 30$ kit and neither time has it worked the cable gets twisted up around the spindle let me know what success I have because both windows driver and passenger front are shot
  4. Hi stupid question is the can box rectangular which would connect into the buttons on the steering wheel ? If this has gone bad on the kenwood aftermarket would it kiss turn signals and wiper functions also
  5. Hi any resolution with this I have the same lights and buttons flashing now nothing no turn signal wipers or volume for radio
  6. Hi I have an aftermarket connected has been good for the last few years. When I disconnect the fuse to the stereo all goes off, any idea where the gateway computer is ? Or if I can isolate the can issue
  7. Hi cayenne 04 CTT weirdness the below list of functions was intermittent now nothing works buttons on steering wheel tiptromic button on steering wheel wipers cruise control pin out adjustment all functionality on the steering wheel except it steers perfectly all fuses are good errors as attached any ideas was intermittent
  8. Hi I've patched mine so much it's a 100$ cable I'm ordering it because it's ongoing.
  9. Must be a small hole I've been driving mine for months with no problems I'm ordering a new cable this week
  10. Hi just had to replace my front drivers side air bag and reused the original sensor now I get air suspension workshop fault checked the height for the front and each side is a little off by a few mm and the back is a little higher, any idea how to reset this error
  11. Thanks will buy a new hose 1st the booster vacumn pump is constantly running
  12. Hi number 19 the pump is working but a tick tick tick when running any ideas ?
  13. Hi Lewis I have a pipe going through the firewall under the pump number 19 on the picture. To get to the other side I have to take off the windscreen wiper and the black panel on the passenger side.
  14. HI does anyone know where each end of this hose connects I've been plugging leaks with fuel pipe from auto zone now my pump for the brakes which one of these cables connects to is always running, could it be snapped behind the firewall under the panel which needs to have the windscreen wiper removed 1st
  15. Depends on the position of the window I think this is the part I'm at if the length isn't right then you won't get it to go up or down
  16. Hi there are better details on rennlist... Under my id . It's a pita of a job and if you can get someone to do it for 200$ go ahead the kit is 20$ when you start take some pictures and post the hardest part up to know is the Torx on the back side of the window you don't have to remove the frame just the black metal with the rivets then use some screw to reattach . You are only looking at 3 rivets there are another roughly 12 around the door If you get the kit with the two bars it's even more complicated to fix from what I've done up to know
  17. Hi all can someone post pictures for a couple of questions 1. of how the cables thread inside or outside of the black door frame frame I've assumed all cables and regulator spindle go inside and comments ? 2. When connecting the door window motor to the new cable and spindle should the window be up or down ? Should all cables be tight ?
  18. This is the angle you put the window in to connect one of the cables around the top pulls get a small hand mirror to see behind
  19. Hi the below picture is my CTT 04 I'm trying to finish it today. The other blog site renlist. Has more details on which recite to remove and my pictures I've been jumping between both to figure this out
  20. Temporary fix for now ultimately the rivets and inner door have to come off to connect the new cable
  21. Hi temporarily a wooden wedge on the outside, long term u need to drill out all the rivets and there are quiet a few those three need replacing with a screws, I've got a couple of posts in this forum and the other one the kit to fix is 20$ eBay but a pita. I have both mine stripped down at the moment I can give you advise no problem
  22. Hi I have a replacement regulator cable and need to know how it connects in the inside of the door without removing the door frame I took the old one out some months back
