smithh
Contributing Members-
Content Count
26 -
Last visited
Calendar
Videos
Forms
Porsche TSB Listings
Classifieds
Everything posted by smithh
Removing the rear cup holder
smithh replied to 4x4's topic in 9PA, 9PA1 (Cayenne, Cayenne S, Cayenne Turbo, Cayenne Turbo S)
Picking up this old thread - I cant seem to work this out either, did anyone manage it? -
Auxiliary battery in trunk
smithh replied to angusc's topic in 9PA, 9PA1 (Cayenne, Cayenne S, Cayenne Turbo, Cayenne Turbo S)
I thought you either had the bose or the second battery not both? I' have bose and have assumed I dont have the other battery. My car is a 2009 GTS. Anyone confirm before I rip the bose out? -
Hi yes, Well after 18months and a lot of miles I can share a few thoughts. Firstly. I've done a lot of offroading in the car. As a result I've picked up or had cuts / splits on 2 of the tyres. This caused me to replace all 4 tyres recently as I was worried about impact during long trips. So I put 4 more BFGs KO2s back one. Immediately after that I 've 1 tyre delaminate following 90mins at 160kph. Not impressed. Tyre has been replaced under warranty, but not sure yet whether the tyre or batch is an issue. Whilst I've never had a BFG actually puncture, I have to say, they are expensive, and they are heavy. Also the on road performance is pretty average, clearly its an AT tyre so you should be prepared. Stopping distances are way longer than street tyres. I"m about to do a 2000km trip, including 220km desert crossing, so lots off road, which will bed the new tyres in one way or the other. But I've lost a bit of faith with BFGs. I'm now 50:50 on whether they are worth the money and the weight penalty. That said, there has been pretty much zero rubbing, and I've even managed to drive the car with the air suspension collapsed. Not far, but it was OK. This was one of the criteria for me, due to the sometimes remote locations we go to. Hope that helps and is a balanced view.
As it happens I've fitted a Motor sports kill switch to my cayenne. Mine is a 2008 GTS, and has the 17" spare and bose subwoofer. However, I needed a kill switch fitted. So I've fitted mine to the base of the drivers seat. I would figure on a car with dual batteries, there is no reason why you couldnt do the same. Out of interest, I'm keen to take the bose out and fit a second battery under the wheel. Not worked out details yet. -
steering column work
smithh replied to ARModen's topic in 9PA, 9PA1 (Cayenne, Cayenne S, Cayenne Turbo, Cayenne Turbo S)
Just want to echo reese5997's comments. I live in the UAE, my steering threw a fault, which meant the car was a paperweight....anyway the garage quoted a huge money for a new column, so I got them to remove it and send to Tom at www.speedosolutions.com. His service was brilliant, took time on the phone, work to cut my postage charge and offered to contact the garage to help them remove the right parts. Any car is back on the road, fully working for 1/3 of the price. Brilliant service. -
All, I've followed a few threads on this topic, not have just attempted it. But I've hit problems. Install initially went fine. My kit didnt come with the MOST loop for the CD changer, and I sourced one of those. I also had a factory TV install, which complicates things, but its now removed and looped out (it does receive channels here anyway). At this point the unit work, I could make calls and play music. Howover, I couldnt control it from the steering wheel buttons, only the console buttons. Anyone any ideas why this is the case? I have wondered if it is linked to the little jumper switches (mine all set to ON. Then, after about a day of working, my unit doesnt power on? The power cables give 12v, but I get no blue light at the back anymore. Clearly this means I have no audio at all right now. I wired the unit into the power to the PCM device. I've noticed with the engine it off, it gets about 11.7v, with the engine on it gets 13.2v. Is it possible that the unit is damaged now? thanks HUgh
Well, its early days, but here is what I can share......I had an SUV, now I have a truck :-). The ride is ruined, its a lot harsher than the road tyres. There is a whine, although not too bad. The car is fine up to about 140kph (not been any faster), and around town you dont notice the difference in noise. Out of town, its a bit of worse, but really OK. Will report back when done a decent long trip. As expected its a trade off, the fear of punctures on trails was too great. having had both old and new tyres side by side when not mounted. the difference in flex is huge. Will report back on sand performance once I've had a chance. I've gone quite aggressive, lets see if that pays off in the long run.
OK - folks, I've done some research and checked my car in detail. It looks like disconnecting the battery and removing this box above (or disconnecting it) is the way forward. It looks like my PCM2.1 doesnt need a code so I should be able to disconnect battery without fear. Further research indicated that actually there is a roll over activation built into the airbag system. Hence the need to do this.
Hi, I need to disconnect the battery, before I do, I dont have the radio code. From a little research I have the PCM 2.1 in my GTS. I think to get the code, I have to call the OPC, but need the serial number of the unit.......can I get this without pulling the unit on the car? Would like to avoid pulling the unit if possible.
OK guys, looks like the only safe way I can work out is to remove the module, whilst off road. This involves disconnecting the battery, which means I need the radio code....going to put another thread up for that. Will then report back. Going to need a quick way to do this, if tis going to be a regular thing. thinking of fitting a cut out switch to the battery.
Hi does this work for Porsche Cayenne 957? A quick suggests its not clear, but that Durametric is the porsche equiv. Although its unclear if you can use it for ridehieght restting. Have you used vag-com for ride height on the porsche? I've not checked video (As in office), will check later. thanks for the lead.... [Updated] OK - there is loads of information on this it seems. Need to go away and read in detail. Looks like Durametric may be the way to go. although I've not used either system.
Actually doing some research, but looking at newer Cayennes it looks like airbags are deployed on impact side and front. Not on roll over. Does anyone know if this is true? If so I would not need to modify the system at all. Function of the airbag system Airbags are a supplemental safety system. Your primary protection comes from your safety belts. The front airbags are triggered during a frontal collision of sufficient force and direction. In the event of a side impact of corresponding force, the side airbag on the impact side is triggered. The inflation process generates the amount of gas required to fill the airbags at the necessary pressure in fractions of a second. Airbags help to protect the head and body, while simultaneously damping the motion of the driver and passenger in the impact direction in the event of a frontal impact or side impact. In order to help provide protection in severe collisions which can cause death and serious injury, airbags must inflate extremely rapidly. Such high speed inflation has a negative but unavoidable side effect, which is that it can and does cause injuries, including facial and arm abrasions, bruising and broken bones. You can help minimize such injuries by always wearing your safety belts. There are many types of accidents in which airbags are not expected to deploy. These include accidents where the airbags would provide no benefit, such as a rear impact against your vehicle. Other accidents where the airbags are designed not to deploy are those where the risk of injury from the airbag deployment could exceed any protective benefits, such as in low speed accidents or higher speed accidents where the vehicle decelerates over a longer time. Since airbag deployment does not occur in all accidents, this further emphasizes the need for you and your passengers to always wear safety belts. Your Porsche vehicle is equipped with electronically controlled systems that help to ensure your vehicle operates properly. These systems monitor the operation of various systems and electronically store information that is useful to service technicians when they need to diagnose and repair these systems
I cant find anything that states function, I know most other systems will trigger if you move from a left gradient to a right gradient quickly, as it can think the car is rolling over. The gradients alone are not the concern, more the change from one to another. Before pulling the thing apart, I'll look some more on system activation, but so far I've not uncovered anything, just evidence that other cars (Jeep cherokee etc) suffer from this. I've had a look at disconnection - it does look a little more complex than first considered. The system has some back up power (not sure where from, so there is wait time for that to discharge, This would be fine. Also the files dont clearly indicate the power feed into the module for disconnection. I cant find a wiring diagram for the car, that doesnt help. Anyone know where to get a wiring diagram for a 2008 Cayenne GTS. Maybe needs a thread on its own.
Hi, I've tried this, it doesnt work. The auto regulation goes back on when the car exceeds a certain speed. I've also heard and tried that fitting the tyre inflation hose into the socket disables ride height changes, but that doesnt work on my car either. I kind of figure that there is a wire with speed feed into the control unit, and you could simply fit a switch inline with this, but I've not found out if thats true, or how to do it. regards hugh
Hi, Does anyone know when the airbags activate, and whether they can all be turned off easily. I've been using the car in the desert a bit, and one of the techniques for traversing dunes, is side cresting, which requires swapping from one side slope, to the other, which puts the car for quite a side angle rotation. This can set off airbags on some cars, but not sure on the Cayenne, so far I've avoided doing this, but am wondering if its an issue or not. Car is a 2009 Cayenne GTS
Hi, I have tried this, and you sadly it doesnt work. The autoregulation seems to switch off once the car is moving. I've also previously read that plugging in the tyre filler hose will stop the suspension from working, but that ooesnt work on my car either. Thanks for the input, I feel there has to be a way. Ideally, I'd like to fit a switch between the speed feed to the control box, but I cant work that out. I was hoping someone has done it. already. :-)
