microtech1
Everything posted by microtech1
  1. Okay, I will weigh my options and see about doing one of the following; Having the dealer or an indy with a PIWIS2 attempt to code the feature Change the belts to the USA model Source a ROW SRS coded module of the same model/feature set I will report back as I make progress. Thanks again!
  2. Wow, thank you so much Richard! This explains the reason why the two US sourced modules exhibited similar faults to me. Now, the dealer states that the SRS module is locked and cannot be modified in its 'locked' state. Is this in fact the case or is it possible to code the ROW features (or lack thereof) into the module after it has been put into service? Is the dealer trying to fish for a bit of $ out of me lol. Unfortunately I cannot ignore the fault codes as it triggers the SRS warning light and therefore I cannot get it past a safety inspection in order to get it plated in my province.
  3. Hello, I have a 2001 C2 996 that was imported to Canada from Japan recently. Prior to departing Japan, the car displayed no fault codes of any sort. During its transit to Canada I imagine the car was improperly jumped many times. I found the fuse box and battery cover misplaced when it arrived at my place.... so obviously the people moving the car didn't take care in properly jumping it. When I turned it on for the first time I found a airbag warning light on the dash. I have taken the following steps so far; I took the car to an indy who read out the codes as 3 and 195. The module was fried from the improper jumps. I proceeded to order a used module part# 99661821901 to replace my module of the same type. The used part was from a 2001 C2 and the production date was within 10 weeks of the original. I ordered a durametric to read the codes for the new module and to reset the light after I replaced the faulty module. I installed the used module and reset the codes. I was then left with codes for "driver and passenger belt buckles" I believe they were 46 and 49 or so. These codes are persistent and reappear after a reset nearly instantly. I understand that the SRS module can be locked to a car, however the module appears to be working and is arming the airbags as there are no airbag related warning codes. Does this lock matter in this case if the donor car is nearly identical in equipment? Should I take the belt buckle errors at face value and repair/replace them? These items appeared to have worked normally before its journey.... Is it possible the loom or contacts became damaged during the events that led to the SRS module needing to be replaced. The car is in nearly mint condition with only 60k km on it. I do not think this is a dust/dirt issue. My temp permit has expired and I will not be able to get another one at this time. My only options are to fix the car myself or transport it to the dealer many many Kms aways. I would like to avoid the cost of a brand new SRS module, esp if the problem is not with that but somewhere else in the system. Any help you guys can provide would be great!
