Miles James
Everything posted by Miles James
  1. Hi folks. After taking the negative off of the battery the other day to reset a warning light, my interior lights now don't come on at all, in the front or the rear. However the rear light that is above the read head rests stays on.. constantly. Could this be a fuse? Have I knocked something moving the seat above the battery, perhaps? Thanks
  2. thanks loren - it was not necessary to remove the cat - you can reach the 13mm bolt head on the knuckle before the rack, just about. thanks for your help.
  3. When on the gas after slowing down or stopping I get a single thump or a thud feeling from under the drivers seat or back of the car area... gear changes are smooth I dint get any knocks or thumps then. Literally when I step on the gas in lower speeds... it’s as if it’s taking up slack in the drivetrain somewhere?? I also get like a whistle at 40- 70 ish mph. Very high pitched. Not your typical whine noise... please help?
  4. Thanks, Loren. Does it say i need to remove the cat, yes?
  5. Hi Loren, it's a 2007 Cayenne 3.6 V6 facelift model.. Thanks
  6. Hi Loren, it's a 2007 Cayenne 3.6 V6 facelift model.. Thanks
  7. Hi guys. Can the steering shaft (Upper) be removed from the column without removing the column? I tried to replace my lower shaft which attaches to the steering rack but can't get it off, and I have pitted the middle shaft trying to knock it off. If not, how long does it take to remove the column? what's involved? Thanks
